Old 12-23-2003, 09:29 AM
ImFlatLine ImFlatLine is offline
Idle problem?
I have a 2001 WS6 Trans Am... The other night I cranked it and it wouldn't idle, then after a few minutes (keeping the idle up myself) it began to idle - still not the normal idle though...when put in gear it went dead... then after a little bit of driving it wouldn't go dead when coming to a stop..
Well, last night I get in it and it cranks and runs fine and this morning it goes back to a rough idle. What gives? Has anyone else had this problem? Any suggestions?
It runs fine when driving, no skip or anything and the alternator appears to be charging. Also has a brand new battery...Please HELP!
Old 12-23-2003, 09:36 AM
Mooose Mooose is offline
Re: Idle problem?
I had an idle issue like that last fall. Turned out to be a vacuum leak at a t coupler.
Old 12-23-2003, 09:46 AM
Hmmm...but wouldn't that cause the check engine light to come on and the computer to store a code? Neither have happened yet....But Thanks I'll look for loose hoses or busted t's/couplers...
I just hate taking it to the dealer cause I know I'll get reamed!
Old 12-23-2003, 09:09 PM
84TrAnSaM 84TrAnSaM is offline
Re: Idle problem?
im sure you have a vacum leak or timeing is off ut im not the smartest
Old 12-29-2003, 02:39 AM
Maybe a vacuum leak, it's just weird because it only does it when it is really cold outside....anyone know why this could be?
Old 12-29-2003, 07:23 PM
1Formula 1Formula is offline
Re: Idle problem?
How about the idle air control valve.
Old 12-31-2003, 06:25 AM
IAC Valve! There ya go, Thanks!
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 08:10 AM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
