Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-23-2003, 09:39 AM
99jeepgc 99jeepgc is offline
Angry 99 JGC Keyless Entry Not Working
The keyless entry for my 99 Jeep Grand Chrokee has been working fine until the other day. I replaced the batteries and they still don't work. Does anyone know what the problem could be? If I bring it to Jeep, they'll charge me a lot for a fix that's probably simple! Could it be a fuse or something similar???
Thanks in advance for any help you can provide!!
Old 01-06-2004, 06:44 PM
JoyNorm JoyNorm is offline
Re: 99 JGC Keyless Entry Not Working
I don't have an answer for you but I am having the same problem. My will unlock sometimes but hardly ever lock. It started after I replaced the batteries but I have no clue. The Jeep Dealership told me that it was wore out and I would have to buy a new one. Not sure if it is true or not.
Old 01-09-2004, 08:35 AM
cw823 cw823 is offline
Same issue with mine. I just remember to lock it as I exit the vehicle. Sometimes the door unlock will work 15 feet away. Sometimes I have to be right next to it. Going to have something else (and add remote start) installed here soon.
Old 01-12-2004, 07:12 PM
bryantyler bryantyler is offline
I know mine won't unlock unless you're right next to it, but I took the remote apart and one of the wires were loose inside. I just soldered it back into place and it works fine now! ~ Cruz
Old 01-14-2004, 03:50 PM
JackGivens JackGivens is offline
My keyless entry quit working on my driverside door. It's fine on all the other opes, just not my driver door. Has anyone had that happen to them before?
Old 01-16-2004, 07:44 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Yeah, those DCX remotes are terrible. There isn't much to do unless you install an aftermarket keyless.
Old 01-16-2004, 09:43 AM
snidelywhplsh snidelywhplsh is offline
Everyone except Jack ( separate problem ),
I assume all people have 99' or newer, its just a remote replacement and its about $40.00. Worth fixing for that.( unless your local dealer is greedy).Jack I'm afraid its your driver door lock actuator and its not the keyless entry .We replace just as many door lock actuators ( latch ) as we do keyless remotes.You people that have 99 or newer Grands,just my ,but we take out or remove a alarm/autostart about 1 every other month or so because it took out the body controller and or door lock-keyless entry module at the same time.I f you do have a "chip" key (grey headed key ) I would advise not doing so.The lowest priced repair I have seen was $400 to fix........
snidelywhplsh Esq.
Old 01-16-2004, 08:26 PM
snidelywhplsh Esq.
Good diagnosis on the lock motor. I overlooked that one. My responce was really towards the others...
Well, you can only HOPE that it's a simple key fob but most of the ones I have seen will not let either keyfob work. SO, what then???
DCX always uses the lowest bidder to make their electronics. I swear that if you would sneeze in the car, it'd blow something.
As far as "but we take out or remove a alarm/autostart about 1 every other month or so because it took out the body controller and or door lock-keyless entry module at the same time...", you must have a bunch of idiots out there installing these things in Jeeps. I have NEVER had a problem with any of the electronics in a Jeep after my installs. Heck, I even work inside a very large DCX dealer. We have an understanding that I wish to be notified BEFORE anyone touches one of my installs. Everyone is happy!
Question, are these installers hardwiring the keyless entry using relays in each front door? I use a databus interface that talks to the computer. So, my unit really doesn't do anything but tell the computer to arm/lock or disarm/unlock. I don't even need to use an extra key to get the vehicle to remotely start either.
Old 01-31-2004, 11:55 AM
Delish30 Delish30 is offline
Send a message via AIM to Delish30 Send a message via Yahoo to Delish30
Jack,
My 1998 Jeep GC had the same problem, the driver's side door comes with an adjitator (not sure if this is spelt correctly), you need to have it changed and this should work fine after. The job takes about 20 minutes to do. Hope this helps!
Old 02-04-2004, 03:34 PM
tkorth tkorth is offline
Re: Re: 99 JGC Keyless Entry Not Working
ponchonutty,
Sounds like you do this on a regular basis. Any advise on how to find someone that will do a good install in my home town? I'm looking for a beefed up keyless entry and maybe remote start on my 96GC. I'm sick of using the key because the system decided it wouldn't work that day.
thanks!
Old 02-04-2004, 05:27 PM
Re: Re: Re: 99 JGC Keyless Entry Not Working
Originally Posted by tkorth
ponchonutty,
thanks!
Not really. Just ask around and go with word of mouth. Ask area dealerships what or who they use. Most any DEI dealer should be safe but I am sure there are bad ones out there. Once you visit a place, see how busy they are and ask if you could see an install in progress. The area they work in shouldn't matter but the end result of the install should look nice and clean. Beware of tape monsters. Most better shops use mostly tie wraps because they do not need to hide their mess.
Old 02-04-2004, 06:23 PM
neoisd1 neoisd1 is offline
hi, i want to ask if anyone knows how to program a remote for a 2002 dodge caravan sport, that is when i do buy it ..dealer ask to much to program and for transmitter
neoisd1
Old 02-01-2005, 06:34 PM
MRSMOOTH MRSMOOTH is offline
this might aply for some of you out their. some times if the remot goes for a period of time with the battery down it will cause the remot to lose it's programming and you will have to reprogramme it.
Old 02-01-2005, 06:38 PM
go to DogeRam.com>TSB's>08-007-02 and you will find the instructions on their. good luke
Old 01-25-2006, 12:46 PM
xtalgrwr xtalgrwr is offline
Question Re: 99 JGC Keyless Entry Not Working
What about unlock works; but lock does not?!
Checked the relay center but I don't have clue which belongs to which circuit? I can feel the unlock relay work and if I substitute nothing improves. Is there an extra fuse for the lock circuit? All fuses in the fuse panel view-inspected ok.
Suggestions?
My Haynes manual shows some detail of wiring. Why don't they include keys to the relay and power centers I'll never understand.
Any suggestions wellcome. Thnx.
keyless entry not working on drivers door [email protected] Explorer | Explorer Sport Trac 0 04-21-2004 01:37 PM
Keyless entry not working 1Bradymichael C/K 2 02-05-2004 09:01 PM
Keyless entry not working garmo Montana/Montana SV6 0 01-05-2004 07:19 PM
1996 Maxima Keyless Entry not working. Fuse? billab2ong Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-21-2003 10:25 PM
keyless entry not working DRGREENTHUMB1001 Blazer 1 07-21-2003 10:36 PM
