Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-23-2003, 05:13 AM
BREAKFAST BREAKFAST is offline
Lightbulb Starting Problems
YO!
I OWN A 93 TEG WITH 90K ON THE CLOCK. I HAD STARTING PROBLEMS WITH THE CAR. I HEARING THE STARTER TURN OVER BUT IT'S LIKE THE ENGINE BARELY WANTS TO TURN OVER. SO THE WHIP IS DOWN FOR TWO DAYS. CONTEMPALTING TO TAKE TO A SHOP TO GET IT LOOK AT. I HAD TWO INDEPENDANT MECHANICS LOOK AT THE CAR TELLING ME IT'S THE FUEL PUMP OR ELECTRICAL. THEY WANTED TO HORSE f@#K ME FOR $450. I CALLED UP THE GURU OF CAR MECHANICS. HE CAME AN IN FIVE MINUTES THE CARS WAS RUNNING. AN I DIDN'T HAVE TO SHELL OUT A DIME. WHAT WENT WRONG WAS THE VALES IN THE HEAD WERE STUCK OPEN SO HE TOOK OUT THE WIRES AND THE PLUGS. HE PUT A LITTLE MYSTERY OIL DOWN THE SPAK PLUG HOLE, REINSTALLED THE PLUGS AND WIRES. FIRED THE bYTCH UP ON THE 2ND CYCLE. IF MYSTERY OIL DOESN'T WORK USE CONVENTIONAL MOTOR OIL USE THREE OIL CAP FULL PORTIONS FOR EACH CYCLINDER. YOU WILL GET SOME COME OIL SMOKE COMING OUT OF THE EXAUST FOR A WHILE TILL YOU DRIVE IT OFF!
NO COMPRESSION SOLUTION.!
Old 01-08-2004, 01:55 AM
jajdiver jajdiver is offline
Re: Starting Problems
Is it still running fine?
I've got a 93 as well - same boat.
Originally Posted by BREAKFAST
YO!
Old 01-08-2004, 02:10 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Re: Re: Starting Problems
hhmm...interesting. i installed some ngk's irridiums and msd wires about month and a half ago and for some reason, on occasion my car will not start, i, thinking it might be the starter or the eletrical system but haven't had a chance to further looking into it yet. this gives me an added solution just in case, well i might try this out first since it sounds simple and i don't have to do any detail probing in my engine bay. oh yes how is the car running? im kinda weary of adding oil in the plug hole.
Old 01-08-2004, 05:31 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
If your valves were stuck open then you need to do a rebuild ASAP! That means that either your valve guides are messed up or that the valve springs are getting too weak or are broken. It sounds more like the guides to me. You really need to find out exactly what the pronblem was so that you can correct it porperly.
P.S also try turning the caps off when you post.
Old 01-12-2004, 02:29 PM
alfaflight alfaflight is offline
I have a 96 civic with a 96 integra GSR engine swap and the engine is doing similar things... it only does it once in a while but when it does do it, it takes a while for it to crank up... i have to keep turning it off then trying again... i usually have to hold the starter on for a while also. the engine sounds like it is turning but it doesn't start. i'm not sure if it's getting worse or more frequent but these incidents don't happen all the time... it's only once in a while... any suggestions on what could be wrong??? i do have AEM adjustable cam gears. could that be affecting it?? any help would be appreciated
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 06:56 PM
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 05:04 AM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 12:13 PM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 08:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
