Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-22-2003, 10:55 PM
RAM9811 RAM9811 is offline
97 yukon keyless entry
I have a 97 Yukon, keyless entry....the remote does not work at all, have changed batteries in both remotes, but still does not work....does anyone have a troubleshooting procedure...
Old 12-29-2003, 03:29 PM
Bas_GMC Bas_GMC is offline
Re: 97 yukon keyless entry
Hi, I think you have to (re)program the transmitters. This is how to do that:
1.Ground pin 4 to pin 8 of the DLC (Data Link Connector) The locks will lock and unlock within 2 seconds as a responce.
2. Press and hold the LOCK an UNLOCK buttons simultaneously, on the first transmitter to be programmed, until the locks cycle (+/- 10 sec)
3. Repeat step 2 for up to 4 transmitters.
4. Remove the ground applied to the DLC
5. verify the operation of the transmitters.
The DLC is located under the steering wheel it is used to connect the OBD.
Old 12-29-2003, 04:05 PM
I think you have to reprogram the transmitters. Thsi is how to do that:
1. Short pin 4 and 8 on the DLC (Data Link Connector) After about 2 second the locks will respond with a cycle (close - open)
2. Press and hold the locjk and unlock button on the first transmitter you want to program, until the locks cycle (about 10 sec)
3. repeat step 2 for each remote (up to 4)
4. remove the short on pin 4 and 8
5. TEST OPERATION
The DLC is located under the steering wheel.
Old 06-23-2004, 08:02 PM
dale_pc dale_pc is offline
These directions worked perfectly! I bought a keyless remote for my 1997 GMC Yukon on eBay for $15.00 plus $3.00 shipping. I used these directions to program it. For $18.00, I got a fully functional remote, which would have cost me about $100 at my local GMC dealer. Thanks for the info!
Old 03-15-2006, 07:15 PM
telecaster53 telecaster53 is offline
5. TEST OPERATION
when you say short pin 4 and 8 , do you mean that i should make a jumper wire and contact these two pins?
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
97 GMC YUKON Keyless Entry Programming Blazer Yukon 1 02-08-2004 07:33 PM
99 Yukon keyless entry programming tdg Yukon 5 02-03-2004 07:59 PM
97 GMC YUKON Keyless Entry Programming Blazer General Discussion 0 09-04-2003 03:27 PM
