Old 12-22-2003, 06:51 PM
hondaaccordboy21's Avatar
hondaaccordboy21 hondaaccordboy21 is offline
Nitrous Wireing
Im having a hard time making my nitrous oxide wired up. Can anyone put some pics up on their Nitrous or NAWZ lol or post a how to make wiring. Thanks
Old 12-22-2003, 09:48 PM
tdoty tdoty is offline
Re: Nitrous Wireing
There really isn't much visible wiring on a nitrous setup; two wires to each solenoid is about it.
If you're talking hoses instead of wiring, then it depends on if you're doing a single point or multi point nitrous system (i.e. Direct Port Fogger). For the single point system, there's one nitrous line to and from the solenoid and another for the fuel (but only if the added fuel does not come from the EFI system - I'm old school, carbs and that crap). For direct port, there is one nitrous line to the solenoid, and then one to each cylinder - into the intake manifold. Fuel lines follow the same rules as the single point style.
Hope this helps - this might too: http://modelcartech.com/nitrous.htm
Happy Modeling,
Tim D.
Old 12-22-2003, 10:28 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
Re: Nitrous Wireing
i think he means the plumbing....
Old 12-22-2003, 10:43 PM
Re: Nitrous Wireing
Yupp. I do. But thanks for the info tdoty.
Old 12-22-2003, 10:48 PM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
Re: Nitrous Wireing
dunno if this will help, but...
http://www.automotiveforums.com/vbul...d.php?t=151314
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 12-23-2003, 12:46 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Re: Nitrous Wireing
Like tdoty said. What kind of plumbing/set-up do you want? Dry system for a model would just a one line in the intake tube close to the throttle body. For direct port you're talking 2 lines for each intake runner on the manifold. Soleniods would be fairly serious work but do-able. There's a couple different set-ups you can choose from. Which one do you want?
nightmaR3Z
Old 12-23-2003, 01:39 AM
Re: Nitrous Wireing
Ill probably just go with the dry system.
