Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 12-22-2003, 06:22 PM
speed_racer_16v's Avatar
speed_racer_16v speed_racer_16v is offline
1982 Mazda 323 carb
Hi all,
I recently bought my girlfriend an '82 mazda 323, bog standard.
It seems to be using more fuel than a 1.5L should and also tends to bog down at part throttle - full throttle is ok.
I have replaced plugs, air and fuel filter and advanced the timing slightly.
The car starts easily and idles happily.
It has a single Hitachi carb which i know nothing about (i'm an SU person).
Can some one explain to me how these carbs work so i can have a look and try and diagnose what's going on?
Thanks,
speedracer
Old 01-12-2004, 04:24 AM
kenneth323 kenneth323 is offline
Send a message via MSN to kenneth323
Mazda 323
Hi!
With regards to your girlfriend's car. I own a modified version with twin carbs. The car should make between 28 and 36 Mpg, depending very much on the way driven, as it has a double barrel carb. Hence first you are using the primary and then the secondary one. If it is not working well on low revs, I suggest, you clean the carb properly, first by using a good additive and then if needed taking out the jets. These cars don't like being driven slow, as they build up carbon, since the carbs are designed for a higher flow of fuel.
I hope you find this useful, if not, I'll be more than happy to help further.
Best Regards,
kenneth
