Old 12-22-2003, 03:48 PM
drumcat's Avatar
drumcat drumcat is offline
Talking 2 new projects Muscle and import
ive been working on these for a few days now the purple one is an oldsmobile w-30 442 and the unpainted car is a toyota cerumo EXIV jtcc the olds is painted boyds candy purple pearl im traying to make some side skirts and some touch ups on the cerumo to make it street looking which rims do you think i should use for the toyota? the white rims or the integra rims? heres the pics....btw im a noob to to modeling which wing should i use ?
Old 12-22-2003, 04:52 PM
drumcat's Avatar
Re: 2 new projects Muscle and import
.............no one likes the cars................lol
Old 12-22-2003, 05:03 PM
Zwaag Zwaag is offline
I cant wait to see that toyota built- I think that gt wing looks good, but I also think you should go with the kit wheels
Old 12-22-2003, 05:08 PM
drumcat's Avatar
thanks thats what i was thinking too with the toyota
Old 12-22-2003, 06:00 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Only got about half of the pix...
Looks like you put way too much paint on the 442 in a single coat, search some of the FAX on painting to learn about mist coats and wet coats.
SCCA 7, The lost Z
Old 12-22-2003, 06:07 PM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
Well, I understand you're new, and I'll be honest in the fact that I made the same error on my first models too, but you've got a serious issue with the paint on that Olds.
As you can see in this pic, the paint did not adhere to the body at all. Instead, it ran down the sides of the body and puddled at the edges of the bodywork. There are two reasons for this.
1: You did not use a primer. Primer is one of the most crucial things in painting a body, as it creates a paint friendly surface that paint can easily adhere to, as well as hiding the color of the plastic. Trust me, once you pick up an older Monogram or Revell kit that's molded in bright orange or lime green, you'll know just how important primer is.
2: You used too much paint at once. When painting a body, you can't apply all the paint at once to get color. Color needs to be built up in fine coats, starting with a barely visible mist coat that you let dry until its tacky, and then go on to a second, slightly thicker color coat. You keep at this until the model is completely coated, gradually building up color in fine misting coats.
I'll assume you were using a rattle can, and this does make that a bit more difficult. I moved to a Paasche double-action airbrush and compressor as soon as I could afford it, and will never EVER go back to rattle cans.
The engine in the Olds does look pretty good though. So you've got clean building skills. Dunk that body in a coffee can filled with brake fluid to strip off the paint, then clean it with warm soapy water, air dry it, and pick up a can of primer to start over. Trust me, you'll be infinitely more pleased with the results.
Proud Owner/Operator of Haven Raceway and Hobby!
Old 12-22-2003, 06:20 PM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
^^^he speaks the truth!
Zach
Old 12-22-2003, 06:22 PM
drumcat's Avatar
thanks for the tip layla and thanks for the compliment on the engine and i had primer but i went a little old for a few minutes and forgot to use it........and ur right i did put too much paint on at once, but hey you learn from mistakes
Old 12-22-2003, 06:26 PM
Slipknot's Avatar
Slipknot Slipknot is offline
Send a message via AIM to Slipknot Send a message via MSN to Slipknot Send a message via Yahoo to Slipknot
yeah dude take his advice.
Old 12-23-2003, 09:31 AM
drumcat's Avatar
i should be getting a bit more progress today damn the flu
new project, low and mean baggedon 22's WIP - Street 3 08-26-2006 01:36 PM
New Project pics and Questions Savagetendencies '88 - '91 Civic | CRX | Wagon | Shuttlee 1 11-19-2005 10:39 AM
All of my current projects! Got some imports, some muscle, and a little bling. vanilla gorilla WIP - Street 4 10-14-2005 04:01 PM
