| Suspension setups, shocks, springs, tires, handling. |
TEIN owners!!!
I just got my Tein's in and would like to know how low you got em and what settings are you going with. I want to ride on the lowest setting and want opinions on what your going with.:huh:
*Mod List* 2 JL audio W3 12's Rocksford Fosgate 600w amp Tein type NA (1.7) Nokya Arctic purple headlight bulbs Rims coming soon... "I always ride dropped, how bout you?":finger4: |
Second lowest I found is the best compromise between lowering and ride. You'll have to play with the shock settings to find out what you like. Probably start them at about 6 clicks from full hard and go from there.
mrc- which spring rate did you get? i got soft ones and it sits about as low as gforces' pict at 2nd from lowest too. the soft spring was suppose to be longer, but it settled in to be about the same height. mine's set at I think 11clicks from full hard front/rear. u might wanna go 3rd perch from bottom
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too. 2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite) 2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings. Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.fiamm dual air horns. |
Thanks for all the info, I think I got it now.
I am at 1.7" and have stock settings ..
I find the ride good as it is, but maybe that's because I was use to the brutal ride the stock suspension gave me. Clockwise is to loosen or tighten?
G20 Toronto & Surronding Ontario |
What?.... you cant read Japanese??? RTFM!!!
![]() clockwise = tighten (righty tighty, lefty loosey)
mrc - yah, they do click like 23 or 24, but don't use it any softer than 16clicks from full hard (full clockwise, then ccw 11 clicks as your starting point). break those in first too...don't set it up too stiff the first 500miles or so...especially in the cold.
I don't know if it was 5 from the hardest or 5 from the softest. But how hard is it to get to the rear dampers to adjust?
I am at 11 clicks now from full hard .. I will try the car out tomorrow and see how that works for the car.
Thx for all the info guys.
mrc- no prob.
5 from full hard is too stiff for street. you'll be hoppin around too much... 11 clicks is probably borderline with comfort and performance from the NA's. if you try other higher performance dampers youll notice that the NA's rebound is on the fast side.the rears arent too hard to adjust. just pull down the seats, take the rubber trim around the hole to the trunk, take off the clips under the trim, pull out the trunk liner a little bit and you'll be able to access the setting knob. its good to have a flashlight.
I gave the 11 clicks a whirl today. I'm gonna try the 6 clicks - because I found that with 11, the ride wasn't that stiff and not as comfortable. Anyone know how many clicks are the stock settings? When I had them on the stock settings, the ride was great.
direct comparison to the stock ride was about 13 or 14 clicks but the problem is full bump on expressways.
teins recommends starting out at like 6 clicks or something on the manual. under 9clicks is too stiff for street, imo. Id like to use 13 clicks for my commuter.
