Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 12-22-2003, 11:59 AM
JettaIIIGL JettaIIIGL is offline
jetta stumbles on acelleration
i have a 94 jetta gl that in the past few day has been stublimg really bad on acceloration in every gear. i think it could be due to the fact that i just changed the spark plugs, but what happened was that the person who had the car before me didn't take very good care of it and the never replaced the plugs or wires and when i pulled the wire off the plug on the passenger side on the motor i noticed that the top of the plug ( the part the screws off the plug) came off in the wire and i cant get it out so i just replaced three out of the four plugs. it is like the timing is off. also when i rev my engine in nuetral i can hear what sounds like a piece of sheet metal that is loose or something. is it some sort of inspection plate that is loose, or is the cap and rotor making that noise. a friend of mine said that the cap and rotor can make that kind of noise when they are worn out. thanks for all the help
Old 12-22-2003, 01:08 PM
miro1118 miro1118 is offline
Gotta get that 4th plug out. Also replace the wires while you are at it. You are misfiring either because that plug is fouled or because whatever is stuck in the wire is not getting good contact.
I notice a metal vibration sound while accelerating my 96 gls but it goes away when the engine is warm I don't pay it much mind probably just a plate on the converter or something. If you are tuning the car up you should replace the cap and rotor. That is an important part of the car running right if at all.
Hope that helps
Dodge dakota stumbles tinman55 Dakota 1 12-02-2010 11:13 AM
'92 K1500 350 TBI stumbles and recovers while braking / slowing down when warm 1993Suburban C/K 2 03-27-2010 06:55 PM
91 jetta sparks on plugs only when turn key to on mybestconnect '91 - '96 1 02-18-2009 07:56 PM
96 jetta stumble when accelerate, any ideas powerup '91 - '96 3 09-06-2007 01:41 AM
95 jetta stumbles going down the road merick376 '91 - '96 3 01-01-2005 05:58 AM
