Old 12-22-2003, 02:49 AM
Manlaan Manlaan is offline
Wont Start Problem. Suggestions?
94 Metro
When trying to start the car, all I get is a single click like the starter is trying to engage, but just cant turn the engine over. I'm 95% certain the battery is ok, but unsure about anything else. The battery cables themselves are clean and look to have good contacts. I'm not quite certain where the starter/solinoid is to check the cables on that side.
The same problem happened last winter also until the weather got warmer.
Any suggestions or clues as to what could be causing this?
I usually only drive about once a month since I work from home and most everything is within walking distance, but its quite annoying when I do need to go somewhere and to have this happen (but not annoying enough to get it towed and fixed).
Old 12-22-2003, 02:08 PM
pod pod is offline
Re: Wont Start Problem. Suggestions?
i think your battery is toast charge it up and try it
30 mpg in a brick on wheels isnt half bad...
Old 12-22-2003, 02:09 PM
pod pod is offline
also welcome to af
Old 12-24-2003, 05:15 PM
geozukigti geozukigti is offline
Well, could be one of a few things. Bad starter, bad ground, bad hot connection, or bad battery. You've ruled the battery out. Now... you'll see a wire that goes from the distributor to the firewall. I would recemmond taking that wire off, and getting a 2 foot length of 8ga amplifier wire, crimp some nice, proper sized gold plated terminals on each end, and then replace that dinky wire that goes there.
I had my starter do that, and it was because the ground wire that was there melted, because it sucked . Also make sure the positive line is decent. If it's all corroded and nasty, you can run the same power line from the battery to the starter.
Old 02-05-2004, 09:36 PM
Zelgodes Zelgodes is offline
another thing, i've installed a couple of starters, and it takes a bit of movement to get them allinged up, and it starts. but i've had that problem to. fix was a starter replace, mine ran me about 160CAN, so its not all that bad and you can do the work yourself easy
93 del Sol si wont start, something isnt getting power TunerFreak24 Del Sol 12 02-08-2010 01:17 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
Cavalier 94 wont start. Any suggestions dirtybirdy Cavalier 5 01-24-2005 03:25 PM
