Old 12-21-2003, 08:25 PM
mng13 mng13 is offline
Angry 1999 silverado 4.3 won't start
Hello from Vancouver Island B.C.
I recently purchased a 1999 silverado 4.3 auto 4x4 ,60,000 miles. It's been working beautifully, until yesterday I started the vehicle (cold) no problems.Moved it about 20ft,where it sat for about 8hrs. I haven't been able to start it since. The engine rolls over fine, after 10 seconds it stumbles like it's trying to catch then it goes flat I've tried repeatedly to start it as per manual. It's not the security code issue in the ignition switch ,I've had that fixed already.
Is there anything I can check for the cheap fix before I call a tow truck for Mr.Goodwrench? I'm new to G.M. products. I appreciate any advice.
Regards,
MNG
Old 12-21-2003, 09:04 PM
ajcarmack ajcarmack is offline
If your 4.3 W motor has CMFI... which is the one injector with six "spider" lines goint to each cyclinder under the upper intake manifold, you might want to take a look at your fuel pressure.
Old 12-22-2003, 07:46 PM
LastOne LastOne is offline
Sounds a lot like your fuel pump may have gone out. Great idea to check fuel pressure. Another quick check is to take a rubber mallet and beat (hard) on the gas tank while someone else is cranking the engine. Fuel pumps are known to get bad spots on the armature of the motor. The banging is enough to jar it around to hit a good spot. Also check / change your fuel filter.
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
1999 Silverado 4.3 problems JOSH...BAMF Silverado 14 03-31-2009 09:14 PM
1999 silverado 4.3 ckpcmp correlation bak40bum Silverado 1 01-29-2008 07:12 PM
1999 Blazer 4.3 just started losing oil pressure when warm CreekBandDad Problem Diagnosis 6 02-01-2007 02:39 PM
95 Blazer 4.3 won't start hansman Blazer 10 07-27-2005 12:53 PM
