Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 12-21-2003, 08:40 PM
YeTi's Avatar
YeTi YeTi is offline
Send a message via AIM to YeTi
bad cold running
lately my 87 944 n/a has been acting funny.
the weather has been abnormaly cold and snowy, and one day (after the first snow) i tried to start my car and itwas hard starting. then when i did get it started running it sounded like a 2.5L one cylinder under the hood.
it wasn't untill about five minutes of reving and idling did it start running a little more normally, with a loss of power. all the while white clouds came out of the exaust.
after a little while after that i noticed a significant drop in coolant. my first thought is cracked block from the coolant freezing (due to bad coolant/water mixture), so i just recently put some alumaseal in to seal the crack, if ther was one. it now starts fine, however there is still the loss of power.
YeTi
Old 12-25-2003, 02:16 AM
YeTi's Avatar
Re: bad cold running
No One?
YeTi
Old 12-25-2003, 06:48 AM
87Porsche951's Avatar
87Porsche951 87Porsche951 is offline
Well i would guess its a bad cold check valve or from the coolent thing it can be a blownhead gasket which isnt uncommon w/ 944's expecially modified 944's.
Old 12-25-2003, 02:52 PM
930guy 930guy is offline
try a new coolant temp. sensor
Old 12-28-2003, 03:32 AM
YeTi's Avatar
you mean a thermostat?
fook mi! a blown head gasket would not be a fun project to start in the snow...
YeTi
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 01:00 PM
96 blazer hard start cold, runs bad till reg operation temperature timisback4584 Problem Diagnosis 2 08-31-2008 10:18 AM
Look,this is weird. Bad plugs=runs good, Good plugs=runs bad browserealty Villager 6 08-28-2007 10:05 PM
runs real bad cold just runs b ad when warm swamprat Camaro Discussions 6 07-04-2004 03:35 AM
