Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-21-2003, 07:15 PM
rkarrjr rkarrjr is offline
blower speeds
I have two GM products. A Chevy Impala 2001,and GMC Safari 1994. Would you believe I am having the same problem with both? They have a 5 speed blower speeds. They ONLY work on 4&5. Whats up with this? Anyone else having a problem like this. I replaced the whole heater/ac control assembly on the Impala. Still the same only two top speeds. Thanks for any replies.
Old 01-04-2004, 02:35 PM
99ssconv 99ssconv is offline
try a resistor assembly
Old 01-04-2004, 05:02 PM
Re: blower speeds
Thanks for the info,will give it a try.
Old 11-04-2004, 08:46 AM
willida willida is offline
Re: blower speeds
I am having the same problem, only mine only operates on the highest setting. What is involed with replacing the blower resistor switch, I assume the dash needs to come out to get to the switch. Any hints would be appreciated. I have a 1995 Caprice Classic.
Thanks!
Old 11-08-2004, 08:46 PM
Fireplug Fireplug is offline
Re: blower speeds
every car they are located in different places most are on the firewall under the hood
Old 11-09-2004, 07:41 AM
Re: blower speeds
Thanks. I also fouond out that the part is a "dealer" item only.
Old 11-09-2004, 08:32 AM
FastNBody2002 FastNBody2002 is offline
Re: blower speeds
Typically, blower motor resistors are dealer only items. I work at a Ford dealership. The resistor for the Taurus, for example, is underneath the glove box. My 1991 Century's resistor is located rather conveniently in the engine compartment. I'd say either try your local dealership, or give this site a try: www.genuineoem.com We run that site and discount all OEM (GM, Ford, Mopar, Kia, etc...) prices 20%.
Old 05-20-2006, 01:15 PM
71star 71star is offline
Re: blower speeds
Chances are it is resistor assembly. Just had to have mine replaced on Impala-
Old 05-20-2006, 01:39 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: blower speeds
On GM w-bodies, it's inside the car, in the heater box near the blower motor. On the Astro, it is mounted under the hood, but still in close proximity to the blower motor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-20-2006, 06:18 PM
phewop118 phewop118 is offline
Re: blower speeds
The blower motor resistors are a common failure on W-body cars. The most common cause is that when you replace your cabin air filter, you don't seal it well (either the foam surround or the plastic cover at the bottom of the windshield). As time goes, on, water leaks in and rusts the bearing in the blower motor. It becomes harder to turn and the low speed resistor blows. If you notice a hum from it at low speed settings, you may want to consider replacing the blower motor.
blower speed switch timd Malibu 15 11-30-2006 12:58 PM
No high speed blower speed dwad39 M Bodies 1 03-11-2006 09:54 PM
Blower speed (5) not working numedpick Montana/Montana SV6 3 07-17-2005 04:31 PM
Blower Speeds DRW1000 Windstar 3 05-13-2005 10:36 AM
