Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-21-2003, 05:44 PM
yoboricua yoboricua is offline
Lightbulb Need help rough idle
I have a 1995 Oldsmobile Aurora which I'm experiencing rough idle. I have replaced spark plugs and wires, clean the throttle body, fuel filter and air filter.
Getting ready to replace O2 sensor, but the wiring is different. Where do I connect each wire.
If you can give me more ideas I would really appreciated.
AL
Old 12-21-2003, 05:58 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Need help rough idle
Look for vacuum leaks thoroughly. Also you could pull the top engine cover off and make sure all the intake manifold bolts are snug. Don't crack manifold, it's plastic. Does it rev smoothly and make power?
Quality isn't expensive, it's priceless.
Old 12-21-2003, 06:09 PM
Re: Re: Need help rough idle
Did all that. It just the engine shakes at idle. I have pick up and everything is just the idle problem. All the bolts are ok. Also I need to know how to connect the wires on the O2 sensor.
Old 12-21-2003, 06:17 PM
Indy8's Avatar
Re: Re: Re: Need help rough idle
OK, it's best to tune when connected to a scan tool, which is how most adjustments are made to ignition and fuel management. You don't want to start turning screws yourself. I've never changed my o2 sensors, what's different about them?
Old 12-21-2003, 06:24 PM
O2 Sensor replacement
I bought a universal bosch with 4 wires. The wire colors are different that from stock.
AL
Old 12-21-2003, 06:27 PM
Indy8's Avatar
Re: O2 Sensor replacement
No instructions provided?
Old 12-21-2003, 06:33 PM
bustedratchet bustedratchet is offline
Re: Re: O2 Sensor replacement
Take the universal O2 sensors back and get the real ones. Ever tried an injector cleaner ? Another thing to consider is when you do the throttle body cleaning there is a remote chance of knocking some carbon loose and having it stick in the egr valve.
Old 12-21-2003, 06:35 PM
Will try that....
Will get the other one. Thanks. AL
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 07:29 AM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
95 S10 4.3 Z code w/TBI Need Help!! Rough Idle danhil007 S-10 2 03-14-2005 05:45 PM
new user needs help rough idle eddiem27 3 Series 3 11-15-2003 06:27 PM
