Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-21-2003, 05:02 PM
jmgarne jmgarne is offline
Question Beretta starting problem
Have a 96 Beretta with a 3.1L V6. Has intermittent problem of not starting after being driven. Engine will turn over without a problem. Acts as though it is not getting any gas. After it sets for about an hour it will start normally. Any suggestions or ideas?
Old 12-21-2003, 09:16 PM
ajcarmack ajcarmack is offline
I had a '88 Beretta with the 2.8. It had a problem that seems like the one your describing. Mine would start cold and run all day long, but once the engine got a bit of temp on it, it wouldn't start again till it got cold. I found the engine computer to be the problem. Advance Auto or Auto Zone usually carries them and most of the times MOST OF THE TIME allows you to return your elctronic parts if it didn't fix it. Please post what does fix it.
Old 06-19-2004, 09:05 PM
sindi sindi is offline
i had the same problem with my 90 berretta it happened to be the computer would act up when it got to warm there really cheap if you go to a junk yard i only droped $100.00 on it and it runs like a dream. good luck
