Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-21-2003, 04:37 PM
gilje00 gilje00 is offline
96 Grand Cherokee (I6) won't start all of a sudden!
Went out to start it this morning and it was having a HARD time turning over and finally it just stopped all together. I figured...NO BIG DEAL I probably left the lights on overnight or something. So I hooked it up to my other car's battery and got back in the Jeep. It started cranking just fine but now it won't turn over and actually start! Argh! Are these two SEPARATE problems or has something caused BOTH my car battery to die and now not to start. Ignition coil? Alternator? New battery? Come to think of it, Im not even CERTAIN that I left my lights on overnight. What else would drain the battery while sitting still?! It ran just fine last night when we brought it home.
Thanks!
JG
Old 01-10-2004, 05:16 PM
CoolAJ86 CoolAJ86 is offline
Re: 96 Grand Cherokee (I6) won't start all of a sudden!
1996 Jeep Grand Cherokee Laredo
126k miles
-15°F currently
I have the exact same problem and I can't figure it out. Yesterday I bought I new battery and put it in thinking that that might be the problem. It seemed to work and I thought I was all set, but today it happened again. Sounds like it'll start, but won't. Tried Jumping it both times without luck.
Old 01-11-2004, 12:10 PM
farmerscotty farmerscotty is offline
Send a message via Yahoo to farmerscotty
check the crank sensor..........had one that did kinda same way your describing............before it completely died.
Old 02-07-2004, 09:38 PM
Exclamation Fuel Pump
My problem was the that the fuel pump suddenly died.
$412... not too bad I suppose. Could've been worse.
Old 01-25-2006, 11:34 AM
xtalgrwr xtalgrwr is offline
Have the crank and cam sensors checked.
Don't wear out your battery.
Old 12-28-2008, 07:32 PM
mark_a_lucas37 mark_a_lucas37 is offline
1) The shifter has a switch that Allows the Starter Motor to crank BUT cuts-out the Ignition system so the car cannot start. A sympton is that your Guages will All be dead, even thought your stater turns over.
TEMP SOLUTION: Jiggle the shifter shift it back and forth. Them try the key and check the guages.
PERM SOLUTION: Find a competent mechanic who works on Jeeps but does Not work for a dealership (they will typically screw you and although the problem may be documented in a factory bulletin - they may ignore it so they can charge you several hundred chassing "other rabbits" that will Not fix the problem.
2) Check the NEGATIVE/Ground cable from the Battery to the firewall.
3) The crank sensor problem will have MANY other symtoms, such as acceleration and fuel economy problems, and periodic unexplained engine gut-outs while at speeds 40-70mph.
