Old 12-21-2003, 01:46 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
In-line fuse holders
I bought a walmart off brand wiring kit a while back and the inline fuse holder in it went out so I replaced it with a fosgate gold plated one. I also got some fosgate fuses (Platinum). Now my bass seems delayed and when I turn down the volume it takes a sec. for the bass to go down.And when I hit bumps or something the bass just kinda blares out real loud. What is the problem? Is it the fuse or fuse holder??? Thanks.
-Joth
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 12-23-2003, 12:58 AM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
It could very well be if it's not making good contact it would increase resistance but i never saw/heard of it happening before. Check your ground. Remember all an amp needs it pwr grnd rem and signal...
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 12-26-2003, 11:29 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
yeah, check your ground.. and make sure your amp/woofer are'nt shifting in the trunk. my ground gets loose every now and then, and affect how well the bass sounds.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 01-02-2004, 09:50 AM
Easily Distracted
It was a loose ground wire and two blown amp fuses!
Thanks guys/girls.
'92 blue Civic Si
-B17a
