Old 12-21-2003, 01:28 PM
blade34609's Avatar
blade34609 blade34609 is offline
MPFI Fuel Injector Order On Manifold?
Hi,
I just wired the injectors to the ECU and I wanna make sure I did this right.
The fuel injector order goes 1, 2, 3, 4 from left to right on the fuel rail right?
DX injectors go to 1 and 3 and ECU injectos go to 2 and 4 correct?
Also, how do I test my injector resistor box to find out if its good?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 12-21-2003, 06:13 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
no man, injector 1 is by the crank pulley side of the engine, and 4 is by the transmission side of the engine.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-21-2003, 10:23 PM
blade34609's Avatar
Alright I am soo confused.
on this pic http://files.automotiveforums.com/up...87289dpfi2.jpg
it says the injector order is 3,1,2,4 from left to right
on this one http://www.angelfire.com/d20/hcivic8...i_diagram1.jpg
It is 3,1,4,2 from left to right
which one is correct or will they both work?
So I take the yellow DX wire and connect it to the #1 injector
Red DX wire to #3 injector
A7 ECU wire to #4 injector
and A3 ECU wire to #2 injector
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 12-21-2003, 10:41 PM
blade34609's Avatar
Quick question.
What is the order of the fuel injector wires.
From left to right on fuel rail- Is it blue, brown, yellow, red?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 12-22-2003, 10:31 AM
blade34609's Avatar
Come one guys someones gotta help me with this.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 12-22-2003, 10:43 AM
blade34609's Avatar
Alright guys I found the correct fuel injector order.
It goes 4,3,2,1 just like incucivic posted.
I looked it up on http://www.binghamtonlife.com/manual...s/91-23-13.jpg
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 12-22-2003, 01:39 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: MPFI Fuel Injector Order On Manifold?
This is how stock mpfi cars are setup such as the 88-91 crx/civic si:
looking into the engine bay on the intake manifold from left to right:
yellow, blue, red, brown,
4 3 2 1
at the ecu:
a1: brown: injector #4
a3: red: injector #3
a5: blue: injector #2
a7: yellow: injector #1
hope this can help.
also, when I did my mpfi swap, I ran the same color wire directly from the ecu to the injectors. I didn't do any cutting or splicing. I just deppined the yellow and red injector wires at the ecu and repinned the them in their correct locations. I suggest this so that there isn't any breaks in the injector wires.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
