Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-21-2003, 01:10 PM
vesthj vesthj is offline
1996 Yukon Power Steering
I have a 1996 Yukon with 4wd. When I turn the truck to the right, the power steering gets extremely tight. Meaning that I can turn the steering wheel just a little , the truck wants to turn alot, and the steering get very, very easy. This does not happen all the time. I can turn the truck off and it seems to reset itself. All will be fine for a while.
Any Ideas?
Old 03-27-2004, 05:40 AM
club661095 club661095 is offline
Send a message via Yahoo to club661095
Re: 1996 Yukon Power Steering
I had a similar problem w/my 97. GMC developed a variable power steeering pressure system to limit pressure a high speeds to reduce the lickelyhood of rollovers. Unfortunately, the system is seriously flawed. The vary the pressure of the system with a valve in the power steeeeering pump which is controlled electrically. What is probably happening is the control or the valve is screwed up. I got sick of it and disconnected the wires to the pump and installed a good old steering stabilizer shock and I love it. No more problems, smooth predictable steering. This is a classic example of GM messing with a good thing and causing problems.
Good Luck
Old 03-10-2008, 01:43 AM
pop826 pop826 is offline
There Is A Steering Control Module On Colunm Under Dash
Old 09-15-2010, 10:09 PM
markdpro markdpro is offline
This module, I bought mine from HELP part #31025
About an hour to replace.
Slide seat fully back
Disconnect neg ground for at least half an hour to Disable air bags.
Remove 15mm nut to separate steering shaft just before it goes through firewall under the dash.
Push shaft off towards, (through the) fire wall.
The device is in a grey housing concentric to the shaft,
Carefully work back the three plastic clips and the disk will come free
Carefully remove locker (a plastic insert) and unclip junction to device lead.
Slide off disk
The plug will slide out if you tease it through carefully.
Clean shaft with electronic cleaner
Install new sensor the brass goes towards the steering wheel.
There is a slot in the top of the gray housing to locate the wires
Tease the coupling back into position reattach and insert lock
Click the sensor in place
Reinstall shaft and bolt.
