1996 Lumina dash light problem
My daughter's 1996 Lumina dash lights will not come on. I checked the fuse and it's fine. What else can I check? Also, where is the bulb for the dash lights located and how do you get to it? Thanks
Mine, too!
Please share whatever you learn about the dash light problem, as my 1995 Lumina's dash lights just recently went out. I, too, bought new fuses, but it didn't work... about a week later, the tail lights went out, so it's spreading. It's not my primary car, but it IS annoying as I keep having to get something or the other fixed on it lately.
Hmmm... I had that problem fixed a while back. If I recall right, there is a fuse box under the hood that is the problem. It controls not only the dash light, but also the tail lights. The problem was because the box is located under the hood and not inside the car, it corrodes. After loosening the box and looking under it, I found that the wires were rotted away. It was fixed by running new wire.
Re: 1996 Lumina dash light problem
Thanks! I spent about an hour reading through the postings, and this seems to be a common problem. The car was in Upstate New York with me for four years, so it had ample opportunity to corrode. Thanks again!
I hope this works for you. My daughters Lumina is also in Upstate NY, so I know what you mean.
next ur probably gonna have a problem with the blinker switch that costs a pretty penny to fix, we had to do it twice, then the fule injectors, our # 6 went out, then the fuel pump, which i was quoted a grand to replace. $382 just for the pump.
Re: Re: 1996 Lumina dash light problem
the fusebox under the hood has an open bottom so it is exposed to the elements. wonder what gm electrical genius invented that one? road salt gets in there and eats away the aluminum connectors for the fuses and relays. you don't even want to know what that costs to replace. but this will cause all kinds of electrical problems.check this first, otherwise it may very well beyour light switch.
Awesome.
That just saved me about 50 bucks for sure. You guys were right; the fuse itself was corroded so bad it fell apart in my fingers. With a pair of tweezers and a tiny flat head screwdriver I scraped out all of the old crud and popped in a new fuse, and viola. Everything worked. You need to take off the reinforcement bar with a 1/2 in socket first and then pop the top off the fuse box. Easy stuff so far. Then get as much of the old fuse out as you can. By the sounds of the other stories people had to solder in new fuses, but I was able to just clean things up a bit in pop in a new one. If you still need help, email me and I'll send a photo Thanks everyone. |
