View Poll Results: Leaking Coolant
Replace Water Pump Gasket 3 75.00%
Keep Using Coolant Sealant 0 0%
Replace Water Pump 1 25.00%
Voters: 4. You may not vote on this poll
Old 12-21-2003, 10:26 AM
SSAINI5 SSAINI5 is offline
Question Water Pump
Has anyone ever changed a water pump??? Was it easy???? I think my coolant is leaking from the pump since I get an occassional drip from the catalyst right below the pump.
Any ideas?? I have tried some coolant sealant which works temporily.
Old 12-27-2003, 06:48 PM
mobey mobey is offline
Re: Water Pump
if it's leaking on the cat like mine it could be the timing case cover.What a bear.The first thing you do that will save you some time is to undo the bolt to the motor mount and get a block of wood and jack the engine up to pull the water pump.other wise forget about getting the pump out.I yad to pull enough crap out of the way to see were it was leaking from then with a mirror I was able to see it was leaking from the cover and not the pump
Old 09-22-2004, 01:08 PM
CoachKarl CoachKarl is offline
Re: Water Pump
Ditto for my 95, 3.8. The leak is from the timing chain cover. And yes, you need to hoist up the motor about 2" to get the water pump changed out. Don't know about that chain cover though. Tightening up on the TC cover bolts closed to the inlet pipe slowed that drip for a while, but it's back again. I'm keeping an eye on my coolant, and looking forward to the day I get to change my timing gear.
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
