Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 12-21-2003, 10:05 AM
93sentraser 93sentraser is offline
Send a message via AIM to 93sentraser
Timing Problem
ok... heres my problem. I swapped my head off of my 93 Se-r and i have NO idea how to get the timing set back to factory spec. Do you think anyone could give me a step by step thing on how to get my timing set right??
Old 12-29-2003, 03:13 AM
Lawngn0mex Lawngn0mex is offline
Send a message via AIM to Lawngn0mex
Re: Timing Problem
The best thing is to locate top dead center of the #1 firing piston and make sure it's aligned properly. I believe there is a marked position on the belt and a groove in one of the gears where they are supposed to meet, however it is probably worn due to age. (Was on my old honda) My suggestion would simply have a mechanic do it. If you mess it up, you will blow your head and need a whole valve job done. I saw it happen on a 300ZX and it wasn't pretty. (the outside of the car was.
new motor with timing problems gtkid39574 C/K 10 10-10-2009 09:35 PM
Timing Problem WLC Engineering/ Technical 1 07-27-2003 01:21 PM
Pajero 3.5l timing problem ratter01 Engineering/ Technical 0 09-26-2002 02:17 PM
735i -86 Ignition Timing problems jkr 7 Series 0 07-11-2002 04:56 PM
timing problem?? fubaroptik Engineering/ Technical 5 06-13-2002 03:33 PM
