Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 12-21-2003, 08:47 AM
atl atl is offline
1988 735i won't start
I have a 1988 735i that won't start. The fuel pump tested bad so I replaced that. Still won't start. It sputters like it wants to start once or twice but never does. The plugs looked fouled so I replaced those. Again it tried to start for about 1 second or so, then nothing. I think the spark looks a little weak but I'm not sure, I see some blue and some yellow spark. Does anyone know to test the coil and how much it should be putting out? If anyone has any ideas please let me know.
Thanks
Old 12-21-2003, 11:17 AM
KC Ron Carter KC Ron Carter is offline
Hmm,
Check the connection at the coil, green wire to the #15 terminal.
You do not want to measure the spark, it is in the 30 kv range.
You need an oscilloscope to view the spark.
On the coil you can test resistance with a VOM, Volt Ohm Meter.
#1 to center output is 6000 ohms also known as the secondary
#1 to the #15 is .50 ohms also know as the primary
On the Motronic 1.0 there is also the reference sensor on the flywheel.
On the aft intake brace are two connectors the connector with the white tie wrap is the refence sensor and the other is the tachometer sensor.
Sensors are the same just different usage.
On the sensor to check them out use a VOM, Volt Ohm Meter.
#1 and #2 = 960 +- 96 ohms
#1 and #3 = 100,000 ohms minumum
#2 and #3 = 100,000 ohms minumum
Here is a block diagram for a visual reference to the system.
http://members.roadfly.com/kcroncarter/etm119.htm
Later,
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
88 735i Won't Start ps_vee 7 Series 4 04-16-2007 07:40 PM
1988 Caprice Won't start Superman45342 Caprice 1 08-09-2004 08:54 PM
88 735i won't start rykrosgt 7 Series 3 06-10-2004 11:19 PM
1988 Firebird won't start ddboer Camaro Discussions 1 05-03-2004 01:18 PM
