hi everybody once again i was fooling around with my car and i noticed something. Well here's the story i was draggin this white bmw 3 series and when i floored it at 1st as soon as it hits 7000 the car jerks crazy!! does anybody have an answer for me because it might be a serious problem thank you all
VROOM VROOM VROOM!!!!!
Re: Flooring the SPec-V
fuel cutoff?
first time happening?? if not i would have this checked...flooring a specv is fine but redline is 6000rpm and unless you have proper mods to extend your redline to 7000rpm then this could cause problems for your car...especially if you consistently drag in the "red"....they put the "red" on the tach for a reason....check www.hpautoworks.com i believe they have the mods needed to extend the rev limit in the specv
To my knowledge there is no mod or ECU out right now that will extend the rev limiter for the 2.5 QR25DE engine. Like mreff said...redline right now is 6250. So if you are taking the car to 7000 rpm's in first gear then you are a moron. If you can find something that expands the rev limiter on the 2.5 please let us know...it will be news to us all.
Proud Member of PI-Motorsports 2002 Molten Silver Nissan Sentra SE-R Spec V 35,000 Miles **Pre-cat recall done** AEM, Mobil 1 5w-30, AC Autotechnic Reverse Indiglo Gauges, Sparco Grip Pedals ***Courtesy of Grafxwerks: "Spec V" Third Brake Light Overlay, Reflective Dark Red Wheel Inlays, Dark Red Reflective Spec-V Door Stickers |
So you were planning on shifting past 7?
You nailed the rev limiter. It doesn't do any damage (well not any more than bringing it up to the redline in the first place), it's the car's way of saying you need to shift.
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
Yes, you nailed the rev limiter nearly 1000 rpm into redline with no plans of shifting
