Old 12-21-2003, 12:39 AM
SenseiAccord SenseiAccord is offline
Wrong fluid in wrong place... help
I think i put powersteering fluid in my brake fluid tank on one of my old trucks. What would happen if i were to run it and use the brakes? You think some bad will happen or break cuz i guess it would save me money to drive it down to get it fixed than toed.
Old 12-21-2003, 01:32 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: Wrong fluid in wrong place... help
how much did u add? thr reserve tank if i am not mistaken is not actually cycleing through the system, it is there to ensure that there are no air bubbles and to bleed the system. you should fix it it get it fixed asap but as long as you dont stomp on the brakes you should be alright till then
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 12-21-2003, 02:29 AM
BullShifter's Avatar
Customer did that once - power steering in master. We had to replace the almost the entire brake system per American Honda.
Old 12-21-2003, 04:38 AM
Think its like a 50/50 mixture... shouldnt be that bad.. right?
Old 12-21-2003, 07:24 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
You need to bleed your system, and replace all the fluid with brake fluid.
Old 12-21-2003, 11:00 AM
Re: Re: Wrong fluid in wrong place... help
Call the dealer(whatever) your truck is, if they say replace all the parts, then repalce them. Power Steering & Brake fluid don't mix.
Old 12-21-2003, 02:36 PM
mreff mreff is offline
No, thats a serious problem. They are both hydraulic oils but brake fluid is either polyalkalene glycol, or silicone based. Power steering fluid is Petrolium based. Petrolium will eat through the seals which are made for sythentic oils. Get a vacuum pump or whatever, be creative, get the fluid out of the resivior, then blead the whole system, make sure to start with the right rear wheel. watch carefully for any black fluid. If you don't see any you may be ok, but I'd still flush that that system really good.
