Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-20-2003, 08:13 PM
MichaelCady MichaelCady is offline
Send a message via Yahoo to MichaelCady
Angry electrical problems
I was driving home from work last night and my radio sound, front headlights and half of my dash panel went out? Does anyone know what could possibly be wrong?
Old 01-11-2004, 02:03 PM
Brianm80 Brianm80 is offline
I have the exact same problem. I was driving home last night and the radio and heater as well as dash lights cut off and turned back on. After getting gas, the car didn't start (battery was dead). Today pulled the alternater and had it tested, it tests at 15volts normal range is 13-14 volts, I think. Now not sure what to do.
Old 01-19-2004, 01:44 AM
Kinerry Kinerry is offline
Re: electrical problems
Same problem with me, only it's shutting off the stereo when I shut off the headlights for only a second though
Also, it blew a headlight and fuse to the taillights, I have to disconnect the battery when I shut it off or it goes dead
Old 01-19-2004, 08:41 AM
TomPP TomPP is offline
You got a relay problem or circuit breaker needs replaced.
TomPP
Old 01-21-2004, 09:03 AM
Xzavior2003 Xzavior2003 is offline
Send a message via AIM to Xzavior2003 Send a message via MSN to Xzavior2003 Send a message via Yahoo to Xzavior2003
have you tried the circuit breaker? I had a problem with the fuse for my dash panel and what ever else it runs blowing not sure because it didnt have a radio. the only thing electrical I did was change the battery cables and changed the circuit breakers in the fuse panel. so it had to be one of those two because it hasnt done it for about 8 months now.
I would check the circuit breaker then go for the relays. theyre cheaper.
The X man
Old 01-21-2004, 09:59 PM
Turned out to be a defective alternator that was draining power after it was shut off
Old 04-07-2004, 01:09 PM
dustysam dustysam is offline
i have the same problem the dash won't light up so is don't have any ideas to check after the fuses
maybe the digital dash is fried
Old 10-18-2004, 08:12 PM
jiloasis74 jiloasis74 is offline
headlights spazzing on/off when I drive
dang that sucks, just a few days ago my headlights started flashing on/off after Ive been driving for about 10/15min. dont know what to do. Can someone help?
Old 10-19-2004, 07:24 PM
Franky-5-Fingaz's Avatar
Franky-5-Fingaz Franky-5-Fingaz is offline
Send a message via AIM to Franky-5-Fingaz
The alternator puts out amps, and i think T-birds and cars these days usually run like 100 amp alternators right?? well just turning your car on takes a lot of juice. And then running the stereo, heat, blowdryer, pop corn machine and all that is just draining power from the alternator.. Or i mean power that the battery means to give to the alternator.
Anybody up for a Race against a Pearl White 97' T-bird
PeAce
FW
a.k.a
Franky-5-Fingaz
