Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-20-2003, 12:27 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
50$ goes to whoever can solve this problem with MPFI
Hey guys...I am offering up 50$ or your choice of miscellaneous crx/civic hatch parts like clear tails, starters, dizzys, a/c, wutever u want....I promise to give this to whoever gives me the answer with solves my problem.
Here it goes. So earlier this month, I swapped a 91 D16A6 into my 88 civic hatch dx. I encountered no problems besides the fact that it wont start. I've checked over the wiring at least 10 times. I've checked for continuity with a multimeter on all the wires I've added like the 4 injectors(brn, red, blue, yellow), the inector resistor box power (yellow/blk), the 4 injector resistance feeds (red/blk), the 2 dizzy wires (blue/yellow, blue/green) at C1 and C2 and the org. and wht. wires i switched to b10 and b12.
The wires were all fine. I soldered and heat shrunk ALL connections. I also checked the resistor box to see if the resistance was still good...yep, 6 ohms to each of the four wires...perfect. I checked for fuel...yep getting fuel. I checked for spark....yep getting spark. I checked for compression...yep fine there. I'm throwing no ecu error codes except an occasional code 20 which is the code for "electronic load sensor". Which means that I have bad grounding somewhere. But i've double and triple checked all that. I checked all the grounds on the valve cover, thermostat, and transmission. I even ground down to the metal with a grinding bit so that there was a perfect connection to the chassis with each ground.
So wut can it be?
I would also like to add that my battery light stays on. That is obviously because my alternator is bad...but it wasn't bad before the swap. Could it have gone bad through the continuous cranking over of the motor without it starting?
My battery keeps going dead when I keep trying to start it because the alternator isn't supplying the return current it needs. But even when I jump start my car to another car, my battery doesn't charge up. When I jump start my car to someone else's, my car just keeps turning over and after about 10 seconds you can smell the presence of fuel as if the cylinders are being flooded and theres no spark(although there is). I also did switch the yellow and green wires on the TPS in case you were wondering.
I've had code 20's in other swaps but I've fixed them before. I'm guessing that this code 20 is the only reason my car won't start. That's the very last thing I can think of.
I'm no newb when it comes to "honda-tuning" but for some reason...I can't get this car started...it baffles me and i'm frustrated because I'm supposed to be an "expert" at this kind of shit. I'm one of the local people that is known for honda swaps but this mpfi conversion has been the toughest one yet...
Please help me...and as i stated above, the person who posts the answer to my starting problems will recieve $50 dollars...on my word.
Here are the only problems I have:
Occasional code 20..........why?
Battery light stays on.........the alternator is bad but that shouldn't keep the car from starting.
Battery won't charge.....even when boosted to another car.
Thanks in advance
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-20-2003, 01:41 PM
slo89 slo89 is offline
Send a message via AIM to slo89
Re: 50$ goes to whoever can solve this problem with MPFI
So wut can it be?
Thanks in advance
Have you tried the main relay, i did a ls swap in my 4dr and fuel was going into the fuel rail but the relay wasnt turning the injectors on. I changed the relay and it started right up. As for the battery i would say that the alternator is going bad or the belt is loose or something.
Old 12-20-2003, 02:16 PM
BullShifter's Avatar
If your getting fuel the main relay is most likely still good, but I would also still check it.
Have you looked @ a manual for code 20?
http://www.binghamtonlife.com/manual...s/91-11-68.jpg
http://www.binghamtonlife.com/manual...s/91-11-69.jpg
http://www.binghamtonlife.com/manual...s/91-11-70.jpg
Also the whole manual will be of help - electrical & fuel and emmisions. http://www.binghamtonlife.com/manual/2gsm/default.htm
If the alternator is bad, replace it. Test it & the battery. Replace if needed. You can only fix one thing at a time, start with the obvious & easiest.
Old 01-23-2004, 02:13 AM
vxturbo vxturbo is offline
Send a message via AIM to vxturbo
Maybe a bad ground somwhere else on the car? maybe the alternators conections are backwards? that happend in my zc swap somehow and it fried the alternator and wouldnt start.
Old 01-23-2004, 12:26 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Charge up your battery, then wait 10-15 min. then try this...
Put a (Big) Ammeter on the batter gound wire, and put a analog voltmeter on the battery.
If your amps go really high (150ish), and volts hover around normal (10V) low you have a mechanical resistance. (not likely)
If your volts go low (under 8 volts), and amps stay normal (100ish), you have a dead battery, replace it, it is gone.(possable)
Okay if your still getting good voltage, watch the ecu as you turn it on, it should blink once. Then crank and watch for codes.
If none, You can also get a code 20 when a wire shorts out to ground that is not supposed to. My guess is that one of your wires has contacted ground for whatever reason. You may only get a code 20 when the ECU checks this sensor or aplies an output to this device. (I had a similar once, I accidentally hooked injectors up to wrong pin in connector).
-Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 01-23-2004, 02:06 PM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
its the dam altanator
Old 01-23-2004, 02:43 PM
Magik Si's Avatar
Magik Si Magik Si is offline
Main Relay is about the only thing that is popping into my head...you've got spark, you've got fuel,...hmmm..."air" is the combustion components getting air? Cause we all know that even though we have fuel and spark...you need air to burn!
Other than that...ummm...starter?
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 01-23-2004, 06:24 PM
CR50HC CR50HC is offline
I'm by no means a mechanic but, my gut feeling is telling me that you may have a lack of compression. This could be caused by a broken timing belt or misadjusted timing.
Hope this helps. It's worth a check. Troy
[email protected]
Old 01-23-2004, 10:06 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
the code 20 isnt anything to really worry about, i've had it in my car for like 6 or 7 months now tryin 2 fix it and cant figure it out, car runs fine tho, i suggest replacing the battery and alternator,
to be 100% sure, take the battery and alternator to a local parts store and get them to check it, should be a free service, they will do a bench test on your alt to see if it works, and they will do a load test on your battery
also, is it cold where ur located?? pop off the caps on the battery and see if she froze on you... if so, replace it, rarely they work when un-thawed, i've seen a couple at work and those are newer batteries but usually when u have an old one, once it freezes its done for, so check that. a reason for it freezing is that it could have lost its charge a bit then they freeze,
also if u had it sitting on a concrete floor that could make ur battery screw up too,
hope this helps bro
Old 01-25-2004, 02:17 PM
89bxci-vic 89bxci-vic is offline
Send a message via AIM to 89bxci-vic
Did you use the proper injectors and intake manifold(88-91 si/ex)or ecu? Is you resistor box good? One of these could be your problem.
you almost beat me?
you never had your car!
Granny Shifting! Stressed cause your girl's on my lap! Don't worry you'll catch'em in the turns, slow cars can be fun too!
Old 01-26-2004, 11:35 AM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
yeah if your intake maifold is a 92-95 then you dont use the resistor box.
Old 01-26-2004, 11:59 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
it was the 91 Si engine he put into his hatch. So he is not using the intake manifold from a 92-95.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 01-26-2004, 03:50 PM
Re: Re: 50$ goes to whoever can solve this problem with MPFI
FALSE!!!!
Hit me up on AIM ("krustindumm")and I'll try to talk u through the problem, I've had soo many I am fairly good at diagnosis.
Your alternator is not spinning fast enough to charge the battery at cranking speeds.
Run a compression test and post the results.
i wish it was fast
here is my website
Old 01-26-2004, 09:10 PM
Masta's Avatar
yea, we got his alternator tested and it was pretty damn bad lol
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Old 01-27-2004, 07:55 AM
vesper's Avatar
Re: Re: Re: 50$ goes to whoever can solve this problem with MPFI
Originally Posted by Autocratic_1st_Gen
FALSE!!!!
if you goning to say flase then explain your self this subject is really pissing me off. one person says you dont need the resistor box one says you do. wtf is it already????
Closed Thread
