Old 12-20-2003, 10:32 AM
cj99 cj99 is offline
Whats best Way for a DIYer to clean injectors? DNO
Whats best and least expensive Way for a DIYer to clean injectors effectively?
Old 12-21-2003, 02:26 PM
gforster gforster is offline
injector cleaning
I have found the most effective way to clean severely clogged injectors is to actually remove them and take them to a diesel injection or similar shop. They charge about 15 bucks a piece but it is very effective and they test them for volume/flow/spray pattern also. The other method is to buy a can of fuel injector cleaner and the adapter required for your fuel rail and let the engine run on the can contents till it quites, then re-enable your fuel pump. This latter method is a bit cheaper but I think less effective. Good luck.
Old 04-04-2004, 10:02 AM
Three_Fingers Three_Fingers is offline
Re: Whats best Way for a DIYer to clean injectors? DNO
Easiest and cheapest way I've found is to buy one of those el cheapo 'ultrasonic' jewelry cleaners and get ahold of a portable drill stand and a water separator for an air compressor line and some fittings and a length of 1/2" heater hose.
Mount the water separator to the stand and connect the hose to it with the proper fittings and leave the other end of the hose raw with just a clamp on the end.
You can use your compressor @about 40-60 psi or you can even use a bicycle pump (just put a schrader valve on the water separator inlet).
To test for leaking injectors, clamp an injector into the raw end of the hose and fill the water separator with fuel injector cleaner and pressurize it with the pump/compressor.
If the injector leaks, you'll know right away.
Take a piece of coat hanger and bend it so it can hang from the drill stand and so there's a small loop on one end on a right angle-depressurize the injector and unclamp it from the hose and put it in the loop with the nozzle end facing downward.
Take your 'ultrasonic', battery powered $3 jewelry cleaner and fill it with injector cleaner and lower the injector into it (submerge the nozzle ned only-not the whole injector). Turn on the cleaner and relax...TONS of crap will fall out of that injector).
Flip it over after awhile to clean the inlet screen end and be amazed at the crud that falls out.
I made a momentary firing switch (SPST switch mounted in a plastic box with bog alligator clips such as those found on an old battery charger on the battery end and a salvaged injector plug on the other, the switch is wired inline on the positive side).
This way I can clamp that injector back into the hose end and pressurize it again and tap that switch to observe the spray pattern.
Now I dunno what the official spray pattern is supposed to look like but I do know it's supposed to be a fine mist in a more or less conical pattern.
This appears to be good enough.
My engines aren't complaining
Old 06-22-2004, 01:32 AM
yale329 yale329 is offline
Removing the injectors is the best advise, but for twenty dollars you can get a high quality injector cleaner that you add to your gas. It really will do the trick if you also take it for a good hyway run at the same time. Best of luck.
Old 10-18-2004, 04:01 PM
tjfree tjfree is offline
Re: Re: Whats best Way for a DIYer to clean injectors? DNO
If they are really dirty you may want to take them out. Then get some Fuel Power www.lubecontrol.com and keep them clean.
Read up on FP here http://theoildrop.server101.com/ubb/...?ubb=forum;f=5
Old 10-18-2004, 08:06 PM
vipergg vipergg is offline
injector cleaning
The easiest way is to just get a good fuel system cleaner like Techron and run it thru a couple of tanks and if you can do this on a long highway run the better . Then just add this at every oil change .
