Old 12-20-2003, 10:31 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
spark plugs (ADVISE PLZ)
I have a 95 tsi awd TURBO, was wondering what is the best brand plugs to run in my car, have ran some brands but they suck. Everything is stock also.
ERIC THANKS
Old 12-20-2003, 12:33 PM
MrZ's Avatar
MrZ MrZ is offline
Talon69;
I've been running Bosh platinum multi-tip plugs and recommend them highly. These are also commonly referred to as premium platinum plugs. There are other manufacturers that make them, but I've only used Bosch myself.
I've got 207,000 miles on my Talon, and I'm on my 2nd set of Bosch platinum plugs. I put the first set in at about 40,000 miles, I put the 2nd set in at a little bit less than 140,000 miles. Fact is, that first set could have gone a lot longer, but I didn't think it was worth taking a chance on something as inexpensive as a set of spark plugs.
On the other hand, I have probably gone through 4 sets of spark plug wires in that time. The original set that as on the car went bad at less than 60,000 miles, so I've been changing them about every 40,000 miles or so since then.
Mark
Old 12-21-2003, 12:26 PM
Talon69's Avatar
Re: spark plugs (ADVISE PLZ)
ok Mark i will try them thanx alot, i have tried most others but bosh
Old 12-21-2003, 04:14 PM
Talon69's Avatar
Ok mark went to several parts stores today and they cannot get the multi tip bosh plugs
Old 12-22-2003, 05:08 AM
MrZ's Avatar
MrZ MrZ is offline
Talon69;
Bummer. I got my last set at Pep Boys. I don't know that you're going to see any difference between brands to be honest, there are other manufacturers that make them. Here's a link that shows the whole Bosch platinum line up: Bosch
Mark
Old 12-22-2003, 10:47 PM
snickers snickers is offline
Get the NGK BPR6ES
Old 12-23-2003, 02:44 PM
sorry i think it's NGK BPR7ES
Old 12-26-2003, 05:02 AM
stupidsm's Avatar
stupidsm stupidsm is offline
Send a message via AIM to stupidsm
NGK's, stick the those for your car. Boschs are good on euro cars and american cars, but not our cars.
Free @simplyspeed.com email addresses
www.simplyspeed.com
Old 12-26-2003, 11:38 AM
Talon69's Avatar
Hey snickers umm the parts store does not list ngk for my car, just want to make sure that them plugs will work in my car and stupidsm you say the same plug also as the 1 he is saying?
Old 12-27-2003, 12:55 AM
go to either
www.diamondstarmotorsport.com
or
www.turbotrix.com
Either one will help you out. Is it 1g or 2g because I have a 1g and those are the part numbers. If it's 2g it may differ. But go to the websites they'll hook you up with em.
Matt
Old 12-27-2003, 08:29 PM
Talon69's Avatar
Hey thanx Matt i got em and damn they are not cheap!!!!! for the OEM ones they are $5 each and for the better ones they are $12 each, I have the 2g they are different thanx again for your help
Old 12-28-2003, 01:50 AM
what $12? where did you go?? Mine were only $2.50!!!!!!!!! each.
Let me know.
Old 12-28-2003, 01:52 AM
i went to the site and it was $12 for the set. Are you sure you understood him correctly?
Old 12-28-2003, 08:08 AM
diviniti's Avatar
diviniti diviniti is offline
Send a message via AIM to diviniti
Dont put anything "bosch" in any turbo car.
or high output car. they are nasty cheap plugs and will burn up real quick.
DSM's come stock with NGK's, and some of the highest number running guys still use the NGKs.
BPR6ES is stock
BPR7ES is a colder running plug.
go with the 7es if you are running over 14 psi.
I suggest buying both the 6es and 7es. And trying out different gaps on them both. to find your "sweet" setup. you'll most likely notice a very small increase in power.
Old 12-28-2003, 05:31 PM
stupidsm's Avatar
www.simplyspeed.com
