noisy engine
My parents have a 95 LeSabre and it's been a good car with few problems. One issue which is concerning them is that the engine is incredibly noisey. They've had it in to GM and they aren't sure but think it's a connecting rod. The car rattles and ticks loudly when running, loud when cold and still noisey when warm.
Any ideas as to problem? Anyone else with same problem and soln? Thanks. |
Re: noisy engine
Sounds like dry lifters. pull the valvecovers, and use WD-40 and/or brake cleaner to get them to freely rotate. then flush the oil, and change the oil. replave the valvecovers, with new gaskets.
Re: noisy engine
GM isent sure, sounds like one of thoes book smart people work there(you know the type,master techs)
1990 Buick Le Sabre clear cat k&n filter dyno 194 hp@4800rpm 255ftlb@2200 0-60 6.8sec, empty car 0-60 5.2 QM13.5@110, w/nos open full 0-60 4.3 11.8@120(governor) sorry for the spelling, havent learned all english spelling Get used parts shiped to your door http://www.geocities.com/joshey001 inexpensive and garenteed |
Re: noisy engine
Hmmm. Risoline would also work...Can't imagine spraying wd-40 into the motor is a good thing. Come to think of it, it probably wouldn't hurt anything, but I would rather stick to my own tried and true methods. Is WD-40 safe to put in motor oil? Surely not brake cleaner! If you are cleaning it, use risoline! No messy oil flushes needed! A lot less work! Hint: check the oil regularily to make sure it stays at the level it should be at.
Re: noisy engine
both work fine BMM. as long as the oil is flushed to remove the brake cleaner and WD-40, it'll be fine.
I did this about 15000 miles ago on my 94, and she runs great now!
Re: noisy engine
Cool.
Re: noisy engine
i have the same problem with noisy lifters exactly how did u do that did u just the valvecovers off and spray it down into the lifters ? and did u have it running while u did it? or did u take the lifters out?
