Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-20-2003, 08:55 AM
oehm oehm is offline
Send a message via AIM to oehm
changing the alternator
i just bought a 92 sc twincam and i dont no anything about it and the alternator is going out can anyone help out by telling me were the alternator even is in this car and are they easy to change out
thanks
joe
Old 01-26-2004, 02:05 PM
vzwpv2 vzwpv2 is offline
Re: changing the alternator
I have a 1993 SC2 and just replaced the alternator. It is located below the power steering pump and has to be changed from underneath. First and remove the negative battery cable then jack up the front end and support the car securely with jack stands. Remove the passenger side tire. You will also have to remove the plastic inner fender well. Once removed the alternator not too hard to replace. It is secured with two bolts. Mine took me 45min. hope this helps
Old 01-26-2004, 03:32 PM
goldenrod goldenrod is offline
The alternator can be finagled out of the engine bay through the bottom that way you dont have to take out the tire and inner finder. But it is a tight fit.
Old 02-17-2004, 06:29 PM
rpage's Avatar
rpage rpage is offline
Send a message via Yahoo to rpage
Good luck
-Page
[email protected]
1998 Chevy C1500
1998 Volkswagen Beetle
1993 Jeep Wrangler
Old 03-24-2004, 06:20 PM
V-Italy V-Italy is offline
Send a message via AIM to V-Italy Send a message via MSN to V-Italy Send a message via Yahoo to V-Italy
Re: Re: changing the alternator
Originally Posted by rpage
Good luck
Ya get it from under and its tightened with two either 10mm or 13 mm screws
