91 Caprice digital dash
Greetings all,
Hey, has anyone ever swapped the factory digital instrumentation into a 91-92 Caprice? I'd like to think it's a plug in but I imagine it's not that simple. Comments? Thanks. Jim..... |
You can swap a 91, 92, or a 93 9C1 digital instrument cluster directly to any 91,92 or 93 Caprice Classic. It is a plug and play swap. FYI 9C1 is a police package Caprice. So check out your local junkyards for an old police car. Good Luck And if you find an extra one, let me know.
Countilaw
What I want and what I get are usually two different things but I'm cool
Can anyone give me some tips on how to fix my digital display on my dash? All of my lights including the speedometer are "off", at first I thought it was a fuse, but all the fuses seem fine. Any opinions are appreciated. Thanks!
try taking the cluster out and cleaning the contacts and check out this link
http://www.9c1.com/technical/cluster/fix.htm |
just clean the contacts, if that dosent work its probaly no good
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
Re: 91 Caprice digital dash
If cleaning the contacts does not work, last resort would be to resolder the entire board....
It's a pain in the a**, but that's what I had to do to get mine working again.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out 1995 9C1 Caprice - winter beater 1994 Impala SS - newest project 1991 9C1 Caprice - (rip) "There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B |
When you swap out the cluster to electric, does it show the actual miles on your car, or what was on the cluster from the car before?
I cleaned to contacts today, and the dash now works OK, the turn signal indicators are not fully green, they are a little transparent, also the dash does not dim... is there a correction to this..
ALSO. I am thinking about sending it to be repaired to a place in canada, how do i remove the drive selector without stretching the wire |
There is a clip that holds the wire onto the steering column... most likely on the underside of it.
Remove the lower dash panel to see it. Just push it off with a flat head screwdriver....
