Old 12-19-2003, 07:25 PM
c a m a r o c a m a r o is offline
Banned
aluminum blocks
are there any other aluminum blocks besides ls1/lt1?
Old 12-19-2003, 09:10 PM
454Casull 454Casull is offline
Re: aluminum blocks
There are hundreds of kinds.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-20-2003, 12:10 AM
krebs128 krebs128 is offline
Send a message via AIM to krebs128
Re: aluminum blocks
the new ecotec in gm cars, 2.2L, prolly not what you're looking for though.
Old 12-20-2003, 12:36 AM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
many, but the LT1 isn't aluminum, it's iron.
Old 12-21-2003, 02:20 AM
Re: aluminum blocks
they make some lt1/ls1 of alumium, and some of iron-but you've gotta go w/ the iron block of course. especially when you're getting up to 600hp, alumium is light and great and all but it just can't handle power like that.
Old 12-21-2003, 10:05 PM
Re: Re: aluminum blocks
What are you smoking?
Old 12-21-2003, 10:16 PM
carguyinok's Avatar
carguyinok carguyinok is offline
Are you talking about the LT5 ?
Rules of the game fast,good, cheap pick any 2
fast + good = not cheap
fast +cheap = not good
good + cheap = not fast
Because the water has no speed limits
Old 12-22-2003, 12:32 AM
There are numberous LS1s on tsock internals doing over 600 HP firstly, secondly there are many doing more on the stock block with rebuilds. The 1100 HP lingenfelter TT utilizes an aluminum block as well, there is no issue with holding power.
And there was never an aluminum LT1, ever. Not the LT1, not the LT4 either, they are all iron block. A certain few had aluminum heads, the performance versions, and some had iron, more for hte caprice lineup and such, but none have ever had aluminum blocks.
Old 12-22-2003, 10:55 AM
ok, FYRHWK1 you're right, they didn't make aluminum LT1's and i'm sry for openning my mouth before i completely knew about it. but i still stand by aluminum LS1's, you can even buy them here: http://www.cmotorsports.com/engine/l...teengines.html but i never said anything about redoing the internals oh any engine, so i'm kinda lost on that. but i would still reccommend iron blocks over aluminum b/c the bottom line is they're stronger.
Old 12-22-2003, 05:42 PM
Alumium blocks can handle more power then any streetable car can put to the ground, iron blocks are no longer needed for their strength characteristics, they're still used because it costs less to produce them.
Old 12-28-2003, 12:35 AM
SaabJohan SaabJohan is offline
Re: aluminum blocks
This depends on what block you talk about; in general older cast iron blocks tend to be stronger than newer aluminum blocks (because of weight savings). Aluminum does also loose strength over time while a used iron block can be stronger than a new one.
Old 12-28-2003, 07:37 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: aluminum blocks
seasoned iron is the real deal man.
Used iron blocks are great for turbo motors.
usually after about 50k the block is significantly stronger.
Mustangs are nice, but I'd rather have one of these...
Old 12-28-2003, 10:28 AM
Banned
yo mustang, is that a riced up mustang in ur signature?
and does aluminum make up for its strength with its weight? aluminum is like 40% lighter than iron. i thought aluminum would be more durable than iron.
Old 12-28-2003, 12:29 PM
Re: aluminum blocks
Durable? No... Aluminum has a lower fatigue strength.
Old 12-28-2003, 11:43 PM
True, it has no minimal stress failure like iron and steel do, so even the smallest vibration can kill it over time, but they've been used for years now, even before new forging and metals technology came around, and many are still running with hundreds of thousands of miles on them. Sure they're stronger, but when has anyone here seen a newer aluminum block fail? I can't say I've heard of one myself.
