Old 12-18-2001, 07:05 PM
striporstreet striporstreet is offline
Send a message via AIM to striporstreet
b16 in a 91 hb civic si need info??
what quarter mile times should i expect??
Old 12-18-2001, 07:26 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
15s, depends a lot on what suspension mods you get to go with it, and tyres etc.
If its all well setup you may hit mid 14s, or you might get stuck in the 16s.
But factory numbers for my car are low 15s.
Old 12-30-2003, 10:36 PM
Smokn91HB Smokn91HB is offline
Send a message via AIM to Smokn91HB
Re: b16 in a 91 hb civic si need info??
i would guess mid to high 14's.. that is if you are a good driver and you can launch pretty good
Old 12-31-2003, 01:05 PM
Merilious's Avatar
Merilious Merilious is offline
No way Mid 14s with stock I/H/E. Youd be luckey to hit mid 14s. I would say from personal experience that high 14s to low 15s.
Old 12-31-2003, 10:58 PM
JDMsweetz's Avatar
JDMsweetz JDMsweetz is offline
Send a message via AIM to JDMsweetz
Considering it a stock b16, 14.7-15.1 is expected...Like stated above, depends on the driver.
Old 01-14-2004, 09:45 PM
yes if you are a good driver you will see high 14.'s i have seen it happen with my buddies 90 civic hb
Old 01-19-2004, 12:47 AM
salbaje salbaje is offline
Send a message via AIM to salbaje
my buddy has a 90 crx si and has the stock si motor non/vtec he ran 14.0 on 1/4 mile running header, exhaust and homemade intake. he was running on drag slicks. misshifted 2nd so he said he could've ran 13.8 or 9
89 civic, need info caszkl '88 - '91 Civic | CRX | Wagon | Shuttlee 18 05-17-2006 06:29 PM
need info on b16 clutch replacement redlinerjetta How-To's and Walk-Through's 1 03-25-2005 03:17 AM
Blew engine, need info d16 to b16 Laguna Let's get Technical! 4 05-24-2004 04:55 PM
Need info on B16 motor swap autorecess Engineering/ Technical 6 12-10-2003 01:44 AM
Buying civic,,, need info Help please~~ DjiNN_Inc Engineering/ Technical 0 08-11-2003 04:16 PM
