Old 12-19-2003, 05:04 PM
buster730 buster730 is offline
Question 1985 S-10 chevy
Hello
I am new to this site I am not getting fuel to the carb, I checked the fuses, I checked the fuel pump it works but I noticed that I am not getting no power to the fuel pump please help I have been for about 3 weeks,If I cant get it started I will have to send it to the Mech. ANY INFO WOULD HELP
THANKS
Old 12-20-2003, 04:57 PM
Dr Blazer's Avatar
Dr Blazer Dr Blazer is offline
Re: 1985 S-10 chevy
Just a question or 2 first....Being an '85,and having a carb,doesnt your truck have a mechanical (engine-driven) pump? Assuming you have an electric pump,you say "the fuel pump works"....how can you tell if its not getting any power?
Old 12-20-2003, 06:32 PM
poncho62's Avatar
poncho62 poncho62 is offline
Send a message via Yahoo to poncho62
Every 85 that I have seen has a mechanical pump...just ahead of the oil filter. Buster, have a look and see if you have one there. Possibly, its not working.
If you have an electric pump, where is it mounted?
Old 12-23-2003, 11:31 AM
Re: 1985 S-10 chevy
Will first for Dr Blazer I am sorry it is fuel injected and second I took the fuel pump out of the gas tank and put a meter on the wires( going to the pump) I hooked the fuel pump to the battery the pump worked fine,
Now for ponco62 thanks for the info I will look at that when I get home
Old 12-23-2003, 08:00 PM
Dr Blazer's Avatar
Buster...Ok then,if the pump works outside the truck,then I would check things like fuses or inline fusible links for no power at the tank.Check the plug at the tank where the pump plugs in and see if you have power there.
Dr
Old 12-24-2003, 09:04 AM
Re: 1985 S-10 chevy
Dr Blazer I checked the fuses I dont know where the fusible links are, I did check the plug on the truck there are only two wires I tracked them to the front it seems to go to all the lights I am really stumped here Thanks for your help
Old 12-24-2003, 10:07 AM
Strongman00 Strongman00 is offline
Re: 1985 S-10 chevy
HAve you tried doing a voltage drop test on the fuel pump wires? Maybe you have a short to ground, or even an open in those 19 year old wires.
Old 01-05-2004, 04:15 PM
Re: 1985 S-10 chevy
Hello
I did do a voltage test on the wires going to the fuel pump I talked to my mech and he said that it might be a relay I am not sure were the relays ar at or what to do with the relay
I wont to Thank everyone for responding
