View Poll Results: Hyraulic lifters how to repair
thicker engine oil 0 0%
replace lifters 0 0%
Voters: 0. You may not vote on this poll
Old 12-18-2003, 07:45 PM
BLK GTO BLK GTO is offline
Hydraulic Lifters ??
Is it common on 3000gt (gto) to make a tapping noise from the engine ? What would be the easiest way to get rid of the noise...Thanks
Old 12-18-2003, 08:04 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
extreamly common problem, most people chose to live with it.
1st chack to make sure your oil is full, topping it off stopped my friends engine from ticking.
if its full, rev the engin up and hold it for about 2-3 sec at 4000 rpm that should stop it temporarily
some people run a little ATF in their oil to stop it(which is considered dangerous by others)
or buy the "big bore" lifters and replace yours.
Old 12-18-2003, 08:27 PM
Re: Hydraulic Lifters ??
How much would i be looking at to purchase big bore lifters ? And where abouts
Old 12-19-2003, 12:36 AM
They are generally around 25 each, and you need 24 of them. Check your local dealer, they may be cheeper. If not www.3sxperformance.com and sometimes there is a group buy on www.3si.org.
To replace them the proper way you have to disasemble the heads, so add some gaskets to that. However you can do it with a crow bar, just dont slip. Look around on 3si. This is a very common problem.
Old 12-20-2003, 01:12 AM
Im in australia. So are the prices on www.3sxperformance www.3si in Aus$ or US$
Old 12-22-2003, 08:55 PM
ikOnone ikOnone is offline
Us$
what caused hydraulic lifters to fail? bender235 El Camino 3 10-10-2005 03:13 PM
Hydraulic Lifters? roche314 General Discussion 1 07-27-2005 12:09 PM
old hydraulic lifters bimmerman333 3 Series 0 01-19-2005 10:52 PM
hydraulic lifters - question duffbeer911 Falcon | Fairmont | FPV 1 08-31-2004 11:17 PM
