01 wont run
drove couple hours turned off, returned bout 2 hours later wouldnt run cranked fine, chked fuel,sprk,compression,a few other things,sprayed carb spray bypassed mas sensor ran fine while i was feeding it spray soon as i quit it died,changed plugs chked all fuses an relays,no interia cutoff switch,when i first chked plugs , looked fouled, everything ran good before i did any thing except sprayed the carb cleaner while cranking,then i started going thru the motions , chk this an tha changed plugs an so forth,, secruity light acting normal no codes apparent,, any ideas,,
Re: 01 wont run
Did you check fuel pressure? Should be between 52-59 psi.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re: 01 wont run
yes chked fule pressure , roughly 56 during cranking,3.1 liter,chked relays all fine, chked the fule pump soundes normal , weird tho not sure but, during cranking pump wouldnt kik on but when u turn the motror off it sounds as if the pump is pressurizing again,,,baffled,cuz runs smooth with spray,no knock or mis,soon as u quit spraying it shuts down.
Re: 01 wont run
The fuel pump is supposed to run for another second or two after the engine is turned off. It basically keeps the system "primed".
Re: Re: 01 wont run
If you have spark, the next thing Iwould check is injector pulse
