Old 12-18-2003, 05:34 PM
Onder Onder is offline
Send a message via ICQ to Onder
Angry Blazer 97 battery drainage
I have a strange problem with one 97 blazer w AT transmission. It started few days ago while driving - the battery indicator showed up and the voltage gauge started to drop down and after a while the transmission was not working. First I thought the battery was gone but I've checked it and it is OK. Now if I turn the key to start the engine sometimes I hear some clicking noises and the rear door lock is making noises too. When I let the car sit for a while I can start the ignition, but sometimes the gauges are dead or the voltage gauge is dropping down. Last time I 've just turned the key to ON position (engine was not running) and as soon as I hit the brake the voltage gauge was going down. I think it must be some electrical problem (short circuit or so). Have any clues?
Old 12-18-2003, 05:45 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Blazer 97 battery drainage
First, I would recheck the battery condition and take a close look at the cables for signs of corrosion.
Also check the positive feed to the underhood fuse box.
Have your battery checked with a digital battery tester (midtronics works well)
With your comment about the transmission not working, has the SES light come on?
The transmission shift control circuits are powered by the ignition switch (which has been known to cause some problems)
But check the battery and charging system first...low voltage problems play hell with the computer
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-20-2003, 03:53 PM
kabars_edge kabars_edge is offline
Send a message via AIM to kabars_edge
Don't forget to have your alternator checked. Mine did the same thing, I had the alternator checked, it tested GOOD, but after further investigation, I just went ahead and replaced the alternator and that was the problem.
Old 12-23-2003, 10:03 AM
98Blazer 98Blazer is offline
There is a TSB out for 98 blazer so i don't know if its the same for yours, but the red wire that goes to the battery indicator and voltage guage shorts out against the heater hose bracket. Once this happens the battery light will come on and the alternator will not charge, but the alternator itself is still good you just have to fix that wire. The transmission is electronically controlled so if the battery is dying it won't work right. When this happened to me the battery guage would go down and the car would only idle as soon as i hit the gas it would bog down because there wasn't enough power to power the fuel system.
