Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-18-2003, 03:31 PM
aurorarick aurorarick is offline
front end vibration
My 98 Aurora has a persistent steering vibration/shimmy at between 60 and 75 mph. I have (repeatedly) balanced and rotated the wheels. I replaced the tires. It does not occur on braking so I don't think it is the rotors. The front end appears tight. Could it be worn front struts? Any other ideas?
Old 12-18-2003, 07:10 PM
bustedratchet bustedratchet is offline
Re: front end vibration
Sounds like wheel balance. Do you get balanced static or dynamic ? Static = weights on inside only
Dynamic = weights on both sides. Dynamic is the better balance. Also how are they being balanced ? Do they mount it with the wheel center or with the stud holes? I prefer the stud hole method. Also does it vibrate on acceleration ?
Old 12-19-2003, 12:43 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Re: front end vibration
Find a shop that has a Hunter road force balancer. It applies pressure with a roller against the tread while spinning it. This method has worked for many Aurora owners in eliminating the vibration.
Quality isn't expensive, it's priceless.
Old 12-19-2003, 09:52 AM
Thanks for the responses. It doesnt vibrate noticeably on acceleration - I only notice it when I am on the highway at between about 60 and 75. I will try the Hunter road force approach and see if that helps.
