Old 12-18-2003, 01:14 PM
windmonkey windmonkey is offline
F250 ID front axle and LO hubs
Hello. I would appreciate any help with two related issues:
1. Can anyone tell me how to identify what model front axle I have in my 1989 Ford F250 (with 7.3 L diesel)? I am thinking it's probably Dana 50, but some sources I have seen say it could be the Dana 44 HD.
I can't see any tag on the axle, but there is a number cast into the diff housing: RD 820598. I went to Dana site and this number with the "RD" does not register; wthout the letter prefix it comes up as a 0.15" shim.
The axle shaft has 30 splines, & axle OD looks to be about 1.265". I am measuring at tip of axle with hub lockout mechanism in place, so it's hard to mike it precisely.
The doorpost tag lists axle code as 35, but I guess that refers to the rear axle. Same tag lists front GAWR as 4410 lb.
2. The reaon I am trying to ID the axle is to look for a part for the manual hub lockout which broke. The lockout cap says "MM" which my parts store guy said was Mile Marker. Inside the cap is a three-pronged hardened thrust washer thingie. This washer turns with the manual lockout knob, so when engaged the three prongs push on three peaks on the cylindrical part that slides to engage or disengage the axle.
Anyway two of the prongs on the thrust washer broke off. It sure looks like I should be able to remove one snap ring, replace this pronged thingie, and be back in business. But all the parts stores I call say I have to buy a whole hub assembly! In fact they are usually sold in pairs. Part of the general consiracy of planned obsolescence.
If anyone knows where to buy constituent parts for Mile Marker hub mechanism, let me know. Thanks.
Old 01-17-2004, 06:56 PM
big_boy_toys big_boy_toys is offline
Re: F250 ID front axle and LO hubs
Originally Posted by windmonkey
Hello. I would appreciate any help with two , let me know. Thanks.
How rite u are they sell them in pairs,uless u have a auto wreckers close they might have pieces, or one hub. just a guess but it should be dana 50 good luck
Old 01-21-2004, 09:42 AM
ModMech's Avatar
ModMech ModMech is offline
Check your local phone book (or online) for a "4x4" shop. They can sell you a complete new lock-out hub for under $50.
Your truck *should* have a Dana 50 IFS.
Old 01-25-2004, 07:27 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
The <7500 GVWR F250 used a D44IFS, the >7500 used a Dana D50IFS
