Old 12-18-2003, 12:24 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
USB Peripherals
i was recently faced with getting either a new desktop or laptop. i ended up with a 2.6 ghz P4 gateway laptop. since there are no ports for a mouse(i hate the damn touchpad) i bought the one that hooks in through the usb plug. i was just wondering what else they make that works with the usb. i'm particularly looking for a joystick now so i can play ATF and all the other janes games. Also is there anything to give you more usb ports without modifying the PC?
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 12-20-2003, 01:27 AM
Webmaster_Zeus Webmaster_Zeus is offline
Re: USB Peripherals
USB ports suppose to be able to accomodate ANYTHING (well almost). You can get things such as sound cards, speakers, joysticks, tv tuner cards or radio or both, cd roms, burners, dvd burners/roms, scanners, printers, etc. It goes on, and on top of that, each port can be daisy chained with up to 127 devices (the limitation of the binary system or how the port was constructed with precision basically).
So really its quite flexible, but USB are cpu hogs, so unless you really want to tie it up and run cpu critical applications, I suggest maybe not relying on USB too much.
Old 12-25-2003, 05:31 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: USB Peripherals
more ports..you can get a usb hub...most add 4 ports and you plug it into 1 usb port.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
