Old 12-18-2003, 12:03 PM
joshwilson18 joshwilson18 is offline
leak in the hatch, any ideas?
I was putting some stuff in the back of my hatch yesterday, and when I lifted the cover over the spare tire well I found about 15-20oz of water. I looked around at the gasket on the hatch it seems fine. Any ideas?
Old 12-18-2003, 12:25 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..do you have an si? if so...its most likely the drains from the sunroof... they run down inside the car and the hoses get clogged after awhile... take the rear panels off and have a look...
SOLD!
Old 12-18-2003, 12:50 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: leak in the hatch, any ideas?
seriously? my sunroof used to leak but from the actual sunroof area. i checked and found a popcicle stick in the tracks i pulled it out and it quit leaking from that area. however....after ci5ic posted about the sedan trunk i noticed mine was damp. where exactly are the drains you think are clogged???
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 12-18-2003, 01:18 PM
marked001's Avatar
Moderadur
..I'm pretty sure they run right along near the rear hatch strtuts and down to the fender..pull off some plastic and you should see em..
SOLD!
Old 12-18-2003, 01:21 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
mine is leakin from my rear side glass
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 12-18-2003, 01:27 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Man, that little search button works wonders... Took me all of two seconds: Moisture in Trunk
Old 12-18-2003, 01:38 PM
marked001's Avatar
Moderadur
WOW...yer fast!
SOLD!
Old 12-18-2003, 07:00 PM
civ88's Avatar
civ88 civ88 is offline
Send a message via AIM to civ88 Send a message via Yahoo to civ88
yeah mine leaks.....i need to fix it....but thats the least of my worries right now
