Old 12-18-2003, 09:32 AM
boilm's Avatar
boilm boilm is offline
Question Tachometer installation help
I`ve got a 93 daihatsu charade, and I`m trying to install a tachometer, I know where the red, black and white wires go; but have no idea where the green wire goes, does anyone know the location of the ECU terminal or the ignition coil?? thanks
Old 12-18-2003, 11:45 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: Tachometer installation help
the coil is the cilinder that should be mounted to the fire wall, it has a larg wire coming out of it going to the center of the distrubutor, if you remove that wire and boot from the coil there should be 2 small posts on either side of the large center post and one is + and one is -, the tachomiter will connect to the - and you will have to look at the installation instructions to see which color wire it is. from the looks of it it will be the green.
Old 12-18-2003, 02:06 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
mmmm, choclolate.
Old 12-19-2003, 07:44 AM
boilm's Avatar
Talking
Yeah, finally I`ve installed the tach myself, and all is working fine. Just saved myself from spending $65 on installation costs hahaha....
Old 12-19-2003, 10:42 AM
cvcc_wagon's Avatar
great, saving money is always good
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
