Go Back   Automotive Forums Car Chat > Other Cars
Old 12-18-2003, 09:21 AM
boilm's Avatar
boilm boilm is offline
Question Tachometer installation help
I`m trying to install a tacho on my 93 daihatsu charade, I know where all the cable go, except for the green Tacho wire, Does anyone know the location of the ignition coil or the ECU cable on a daihatsu charade?
Could anyone help me?? Thanks
Old 01-11-2004, 12:52 PM
pawn's Avatar
pawn pawn is offline
Banned
Send a message via AIM to pawn Send a message via MSN to pawn Send a message via Yahoo to pawn
very technical question, if i had ever heard of the car i could help.
Old 01-11-2004, 09:26 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
If I recall, a Daihatsu Charade was a small, basic three cyl. car. If you have an aftermarket electric tachometer, you might have a problem if it is not calibrated for three cyl. Ususally they have a switch for 4, 6, or 8 cyl.
If your car is 4 cyl, just make sure the tach is good for 4 cyl.
Otherwise, look for the spark plug wires and follow them to the distributor. There should be an extra spark plug wire going from the middle of the distributor cap to the ignition coil.
Sometimes the ignition coil is built into the cap.
