Old 12-18-2003, 04:23 AM
454_dual_650_carb 454_dual_650_carb is offline
Unhappy its getting hot again
well as we all know the 94 firebird 3.4L notorious for over heating
i back flushed my system and it came out clean no rust at all.
my fan was not turning on so i hard wired a switch and turn it on/off manually, if i dont turn it on i over-heat in about a 1/2 mi. and when i do turn it my temp gauge moves about 10 degrees even after driving for 30min. but when i open the hood the motor is hot as hell. when the car is running and i remove the radiator cap i still have alot of pressure and coolant shoots out for about 2 seconds then im good it has a slow flow im assuming due to the water pump is ready to go. anyone got any suggestions i would appretiate it alot.
Old 12-20-2003, 06:06 AM
95fbodyunder3k 95fbodyunder3k is offline
Re: its getting hot again
i would change the water pump and see if that works out and try the thermosethat
Old 12-29-2003, 01:55 PM
well i changed the water pump, no fun but it has not helped a bit i took it to the dealer and they had no clue why it was overheating the radiator they said was good my hoses are all fairly new.
drive it like ya stole it, unless ya did steal it
