Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-18-2003, 03:55 AM
redhat redhat is offline
Recently lowered - uneven ride-height
Hi Guys
I recently lowered my suspension fitting shortened shocks and shortened springs. My ride-height is uneven, the back still looks like the standard ride whereas the front has been lowered. Is there something that I missed when I did the install?
Old 12-18-2003, 03:17 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Recently lowered - uneven ride-height
Did you put the springs in backwards? Front is rear and rear is front?
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 12-18-2003, 03:38 PM
BullShifter's Avatar
Re: Re: Recently lowered - uneven ride-height
check that ^^^^^
also drive the car & come to a complete stop with as little braking as possible on a level surface. Then check it with the e-brake OFF.
How can we tell if you missed something? It's not like we can see the car or were there with you during the install.
What springs/shocks?
Old 12-19-2003, 12:55 AM
Is it possible to get them mixed up(front to back, back to front)? I'll have a look but I don't think so.
Thanks
Old 12-19-2003, 01:03 AM
Sure, you could also have them upside down
Old 12-19-2003, 01:12 AM
Upside down you say. And that would also affect the height?
I'll take a look and let you know the outcome.
[I must say I'm mightily impressed with this forum. Very quick responses.]
Old 12-19-2003, 01:27 AM
What suspension set-up are you using?
The side with the closer coils goes up, usually. If not set right the spring won't sit properly. If the fronts are on the rears/rears on fronts - the front would be lower since front springs are stiffer than rear.
Welcome to AF, btw.
Old 12-19-2003, 01:35 AM
It's a South African make, Koenic Spring, and an uprated Gabriel shock. You've probably never come across them.
If I look at the back setup, the more compressed coils are on top.
Is the front springs not narrower than the rear springs?
I've attached a picture:
http://home.worldonline.co.za/~abstr...4-2472-IMG.JPG
Old 12-19-2003, 02:05 AM
I've heard of Gabriel shocks
Rear springs are normally* smaller in diameter compared to fronts.
Nice clean lookin' car. The back does not look right, front looks good though.
Old 12-19-2003, 07:50 PM
csaddict's Avatar
csaddict csaddict is offline
Is the spring all the way down in the perch? I had a crap set of coilovers that wouldn't sit all the way down in the perch and it did the same thing.
[size=1/2]96 Civic CX Hatch
1.6 Non VTEC
Full length CAI
Custom Catback Exhaust
Short throw
H&R stage II springs
Tokico Illumina adjustables
front upper,rear upper,rear lower tie bars
ST front and rear sway bars
BOOSTED![/size]
