Old 12-18-2003, 01:45 AM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
tellin the tranny yr...........
i have a dohc zc in a crx si.......how do i tell the year of the tranny?
i have to get a new clutch, and need to know the yr of the tranny. someone told me count the splines.....but there has to be an easier/quicker way.
Old 12-18-2003, 02:11 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: tellin the tranny yr...........
Well which tranny did you use when then new motor was put in?
Old 12-18-2003, 02:25 AM
the zc tranny
Old 12-18-2003, 08:50 AM
Registered User
Re: Re: tellin the tranny yr...........
is their a spline difference in the zc's? I thought there only was in the si trannys
Old 12-18-2003, 01:04 PM
someone told me that it was:
88 20 spline
89-91 21 spline
Old 12-18-2003, 01:28 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
88 20 spline
89-91 21 spline
The pressure plate doesn't matter. You can use an 88 transmission on and d series block as long as you use an 89+ clutch disc and flywheel. Oh yah also, the 88-89 clutch is smaller than the 90 and up so if u got an 88 tranny, then purchase a 90+ clutch disc and flywheel.
I'm 100% sure it's the opposite:
88: 21 Splines
89-00: 20 Splines (d series)
for more info check out:
http://dmoore.com/crx/tranny.htm
Why Honda did this? I got NO idea...pretty stupid if u ask me.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-18-2003, 02:24 PM
so my best bet would just be get a clutch kit for like a 90 crx si?
Old 12-18-2003, 02:39 PM
bambam89lx's Avatar
AF - Advisor
That would be fine...just don't get one for an 88 or 89 cuz they don't grab as good....just remember, you need the flywheel and clutch disc. The pressure plate isn't specific for the yr.
Old 12-20-2003, 05:05 PM
i just looked on the block, and it was stamped 88.
Old 12-21-2003, 07:24 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
the pressure plate IS specific. im doing a stock swap right now on a blown headgasket engine, and the old engine is a 91 and the new engine is an 88. i got a clutch kit for a 91, but the pressure plate wouldnt attach to my new engines (88) flywheel, even though the clutch disc would fit on the input shaft. so heres the deal. if you are gonna swap to another tranny, get the flywheel while you are at it. because not only are the spline counts different on the trannies, but the bolt and dowel pin patterns on the flywheel are different as well.
i ended up having to take the flywheel offa the 91 engine and getting that turned, and then using it on the 88 engine.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-22-2003, 03:16 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
My ZC tranny was different than the 90-91's, and ended up needing a clutch and flywheel from a 92-95, cuz the ZC's were made in two generations, so you need to check the splines to be absolutely sure for the generation. Also, unless I'm wrong, the flywheel is different too. However, I am not 100% sure on this as a rule, it's just how mine worked out.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 12-22-2003, 11:03 PM
i hate bc its my only car, and i cant be w/o a car for like a week.....hafta take the tranny out, count splines then order the clutch.
ugh
Old 12-23-2003, 12:00 PM
bambam89lx's Avatar
AF - Advisor
ugh
like everyone said, just order a clutch kit/flywheel from a 90-95 civic d series. Get either the 90-91 or the 92-95. They're the same. This way you won't have to count the splines. As long as you purchase the flywheel too, it will fit even if ur tranny is an 88.
Old 12-23-2003, 01:36 PM
EF You's Avatar
EF Life Giver
Re: Re: Re: tellin the tranny yr...........
wrong! if the tranny is an 88, you need to make sure your clutch disc will fit on the input shaft, and the 4 speed tranny has a smaller shaft size than the 5 speed. i know this because i was putting a 5 speed in a car, and everything but the clutch disc fit. i ended up having to bring the set back and get one that would fit both the input shaft and the flywheel i had already turned. things got mixed and matched, and now it works. count the splines, or just use an alignment tool to check your old clutch disc and compare it to the new disc.
Old 12-23-2003, 01:44 PM
bambam89lx's Avatar
AF - Advisor
Re: Re: Re: Re: tellin the tranny yr...........
Sorry about that man....yah I knew that. I just wusn't reading wut I was writing...lol...know wut I mean? Wut I really meant is if you got an 89. Yah the 88 has 21 splines on the input shaft. So ur gonna have to get a clutch kit for the 88 if that's wut u got....I knew that...damn im stupid...lol.
sorry for the confusion
