Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-18-2003, 12:09 AM
chamblisso chamblisso is offline
Outside temperature way off
The climate control system displays an outside temperature that is over 100, when the real temp is 30. The heater won't put out heat. I found the sensor in front of the radiator and when it is disconnected it makes the temp. flash 55. The sensor seems OK when I put an ohmeter on it ( it showed ~8.5k at inside room temp.) What should I check next?
