Old 12-17-2003, 09:44 PM
86GLHT 86GLHT is offline
Send a message via Yahoo to 86GLHT
96 Escort no start
Hello all. Well I'll make this short and to the point. 96 Escort 1.9 5speed. 214,000 on her. I'ts my dads car and it won't start. I tried a coil pack to no avail. The car has spark and fuel but won't start. I grabbed a ignition module from work.(salvage yard) But ofcourse the engineers had to move it in 96 compared to the 91-95 cars. Anyone know where it is and if it might be the problem?? Or does anyone think it could be the ECU??
Thanks in advance,
Charlie
Old 12-18-2003, 12:48 AM
need4speed420 need4speed420 is offline
Re: 96 Escort no start
try presing down on the accelerator a tiny bit, and if it starts, then there is your problem, your iac needs to be replaced
Old 12-18-2003, 07:13 AM
nope, tried that. Thanks for the suggestion though.
Charlie Ward
Big Lake,MN
Old 12-18-2003, 11:47 PM
herefordman herefordman is offline
Do a compression check, anything unusual ?
With 200k on it they were very prone to cracking and dropping out valve seats, makes it kind of tough to start like that.
Old 12-19-2003, 06:40 PM
Unhappy
Hmmm, I had kind of that about that. I'll grab my compression tester and try that. Looks like I'll be futzing with it while I'm on my christmas vacation.
Charlie Ward
Big Lake,MN
Old 12-20-2003, 11:13 AM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Check the timing belt.
I make slow Escorts less-slow.
My cardomain
Old 12-20-2003, 01:31 PM
kharris kharris is offline
Internal combustion engines need compression, fuel and spark to run. You say you have fuel and spark so the ignition module is good. Check the compression. Should be over 100psi with the high mileage without a 15 psi difference between cylinders.
Old 12-21-2003, 08:56 AM
jeffescortlx- thanks for the suggestion but he just had one put on about 2 months ago. It doesn't sound any different when you try to start like if the timing belt was broke.
Charlie Ward
Big Lake,MN
Old 12-21-2003, 09:02 AM
Wink
kharris- Read all of the posts, I said I was going to do a compression test sometim this week.LOL Thanks for the lesson on internal combustion engines though.
Charlie Ward
Big Lake,MN
