Old 12-17-2003, 02:11 PM
houtendvan houtendvan is offline
Error readings ? and Electric tricks
Hi all,
Everybody here are talking about error readings. Error 37, error ?? ... How do you see these errors ? Is there a trick to display the error ? Or do you guy's go to the dealer and hook it up to the computer ?
Are there more tricks by pushing some combinations of buttons ? I know how to reset the flashing airco buttons and the auto doorlock @ 25km/h.
Are there more ?
Dennis
Old 12-17-2003, 05:18 PM
RAFAEL VAZQUEZ RAFAEL VAZQUEZ is offline
Cool error tricks
hi dennis
within 5 seconds.....
you turn the key to the RUN position (not START),
then you turn to the OFF position,
then to the RUN position again,
then to the OFF position again,
then to the RUN position again.
the CHECK ENGINE light will begin flashing,
you count the number of times it flashes to get the number.
it will flash a number of times with SHORT intervals,
this is the first number,
then there will be a LONG interval,
this means the next number is comming.
then it will flash a number of times with SHORT intervals again,
it will give you all the stored codes.
when it flasshes 5 times-long interval- 5 times,
that is code 55 which means END OF CODES.
then you'll need a HAYNES or CHILTON book to decipher the codes.
hope this helps
Old 12-21-2003, 06:06 PM
Flashfox Flashfox is offline
Re: error tricks
Originally Posted by RAFAEL VAZQUEZ
hi dennis
...then you'll need a HAYNES or CHILTON book to decipher the codes.
hope this helps
Hmm... I have the Haynes 1984-1995 Dodge Caravan manual and I don't see any reference to the error codes.
Any other source?
Old 12-21-2003, 06:40 PM
Deniz Deniz is offline
Re: Re: error tricks
Any other source?
I suggest you to flip to chapter 6-17...
Old 12-21-2003, 06:50 PM
Re: Re: Re: error tricks
With egg on my face, I flipped to that chapter and realized that I should have looked before asking...
Thanks for the "wake up" ;-)
Old 12-22-2003, 09:10 AM
Oke.....
And which light should be flashing when you have a Diesel like I have ?
Specs:
Dodge Ram Van (Caravan in the US) 2.5 TD, 2 seats only.
213.000 KM or 132.000 M.
Color: Whit.
Transmission: 5 speed manual.
Tires: Michelin 215 / 65 / 15.
VDO Dayton Navigation MS 4150 R C-IQ
Old 12-22-2003, 04:05 PM
Lightbulb Tricks and Error Codes
hello hout
I have always found the error codes in the "Emissions and Engine Control" sections of the "Haynes" books for all vehicles including diesel.
